Tire-Size-Calculator.info | Compare tires and wheels + graphical demonstration - JeepForum.com
post #1 of 8 Old 09-11-2013, 08:00 AM Thread Starter
badger84
Hello Forum!
I want to introduce you to my newly released tire size calculator:
www.tire-size-calculator.info
You can compare your existing and future tires and / or wheels of your vehicle. You also get a nice graphical demonstration of how the tires and / or wheels look like in comparison.
You can calculate values such as circumference, speedometer difference, changes relevant to the ride height or the effect of wheel spacers and learn which tires or wheels fit best for your car.
I hope the tire size calculator can help you with your calculations and helps you in deciding on which tires and / or wheels to choose!
Would be nice if you have any suggestions or requests how to make the tire size calculator even more better.
Greetings Mike!
PS: Admins or mods are welcome to make this thread sticky to help also new members of the forum who could need this tire size calculator.
badger84 is offline
post #2 of 8 Old 09-24-2013, 02:33 AM Thread Starter
badger84
Hi to everyone!
I got a lot of feedback and many of you wanted to be able to input inch-values and not only metric ones. This is now possible Hope it will help you with your calculations.
If you like the tire size calculator it would be great if you could recommend it also to others!
badger84 is offline
post #3 of 8 Old 09-29-2013, 09:32 AM
silvanus
doesn't work at all!
silvanus is offline
post #4 of 8 Old 09-30-2013, 02:49 AM Thread Starter
badger84
Hello silvanus,
can you please explain what does not work?
badger84 is offline
post #5 of 8 Old 10-06-2013, 08:21 AM
silvanus
It's not responding to my specs, how can I get it to work?
I'm trying to calculate the difference between an 33-10.5-15 & 31-10.5-15 both on 15x7 5.5 offset wheel, all in inches??
I'd appreciate the help, very cool calculator my friend!!
silvanus is offline
post #6 of 8 Old 10-07-2013, 01:53 AM Thread Starter
badger84
Hi! Looks like 33 is not the width, but the height? The calculator only supports tire sizes like 225/45 R17 (width, aspect ratio, diameter)
badger84 is offline
post #7 of 8 Old 10-17-2013, 04:47 PM
mschi772
1997 XJ Cherokee
Many offroaders and truck owners would probably appreciate the ability to enter sizes like 30x10.5r15. I think that's what the request for inches earlier was getting at. Lots of people use tires with this size format instead of P-metric format.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #8 of 8 Old 10-19-2013, 07:09 PM
GilaMtnJeep
GilaMtnJeep's Avatar
This^^^
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
