Tire size with 4" suspension 2" body lift - JeepForum.com
post #1 of 6 Old 03-24-2011, 01:27 PM Thread Starter
KenJ
I have a '99 wrangler that I just put a 4" skyjacker rock ready bent arm suspension lift and 2" body lift. What size tires and wheels do you recommend for mostly rock climbing and some mudding. I have stock fender flares but I'm planning to swap those out for something else fairly soon.
Thanks!
KenJ is offline
post #2 of 6 Old 03-24-2011, 02:59 PM
gmgreen
1983 CJ7
You can run 33's with that much lift with no problems. Some others might chime in that you might be able to run 35's.
gmgreen is offline
post #3 of 6 Old 03-29-2011, 07:56 PM
danb303
35's. A guy at work has that same lift set up and he runs 35's
danb303 is offline
post #4 of 6 Old 03-29-2011, 08:41 PM
Peterpsc
R U runing stock axles and gearing? Although axles/gearing have nothing to do with fitting 35s under your lift it will help you determine whether or not you'd want to. Fill out your profile that'll help others with providing responses.
Peterpsc is offline
post #5 of 6 Old 03-29-2011, 09:15 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can fit 37's but like above it depends on your axles, steering, brakes, gears etc. to whether or not you want to. I wouldn't recommend anything over 32's with stock gearing and the 4.0L, or 31's with the 4 cylinder and stock gears.
xjfever is offline
post #6 of 6 Old 03-29-2011, 09:45 PM Thread Starter
KenJ
Everything else on the Jeep is still stock... for now.
KenJ is offline
