Tire size ? - JeepForum.com
post #1 of 6 Old 08-16-2013, 07:45 AM Thread Starter
Deadhorse
Tire size ?
My tire size now on a set of American Racing rime is 235/75-15, would it be possible to replace them with a set of 265/70-17 or will the rims only take the size that's on them now?
Deadhorse is offline
post #2 of 6 Old 08-16-2013, 07:48 AM Thread Starter
Deadhorse
How about 245/65-17?
post #3 of 6 Old 08-16-2013, 11:33 AM
Tailwheel42
No I'm sorry to say you would have to get 17 inch rims to run either of those tires.
A 245/65 - 17 is similar in height and width to a 245/75 -15. Although I'm not sure if many manufactures make a 245/75 -15.
I think the 265 / 70 - 17 would be similar in height and width to a 31 X 10.5 - 15 tire.
If you're just running 235 / 75 - 15 right now, I think 30 x 9.50 - 15's or 31 x 10.5 - 15's would work great on your current American Racing rims.
Tailwheel42 is offline
post #4 of 6 Old 08-16-2013, 11:57 AM Thread Starter
Deadhorse
Thanks.
post #5 of 6 Old 10-16-2013, 07:56 AM
Freemaniz
2014 JK Wrangler
you can play around with the width 235/245/255 and the height of the side wall 65/70/75 but not the last number which is the diameter of the wheel.....sorry dude
go to tirerack.com and click (search by size)> then (all sizes available) you can put 15" in there and it will give all the available size tires you can put on a 15" wheel. click the (specs) link underneath each tire and it will give you a range of wheel widths that each tire can be used on. i havent found another site that allows you to do this!
hint: the middle number is a ratio so if your looking for the biggest tire find the widest one that will fit, then the highest aspect ratio or (middle number). But that doesnt work for flotation tires which are sized by the fully inflated dimensions.
Freemaniz is offline
post #6 of 6 Old 10-16-2013, 08:14 AM
cjcocn
1993 XJ Cherokee
What is the tire sizes that are basically a 30 or a 31? The sizes are something like 265 70R15 or something for the 30s.
Thanks.
1993 Jeep Cherokee Sport; 4x4; 4 door; manual transmission; 4.0L inline 6 cyl.
1999 Jeep Cherokee Sport; 4x4; 4 door; auto transmission; 4.0L incline 6 cyl.
cjcocn is offline
