Tire siping, and other wives' tales.. - JeepForum.com
post #1 of 22 Old 11-04-2015, 09:10 AM Thread Starter
buddastrat
Over the years/decades.., reading a lot about jeep guys getting their tires siped..and how it's pretty cheap and beneficial for traction on packed snow etc.....Many times I've tried to find a place to do it. Calling every tire shop in the area and even an hour or two drive, and they don't even know what I'm talking about, the mechanics, the manager.. have never heard of anyone doing that. I always go through this same thing, and then give up.
I read about Discount Tire doing siping. I called them and they actually heard of it!!! Yay,....but.....said they stopped that years ago because it voids warranties. I can understand that, but why not for an older tire, or they should allow it to be up to the customer to choose. I could've definitely used some sipes on my rubi's old MTRS through many of the winters.
I almost traded for a Willys JK, (came to senses keeping the TJ) which comes with BFG MT's. I'd want them siped, and started that process again. Same result. It's like looking for Bigfoot or somethin'.
buddastrat is offline
post #2 of 22 Old 11-04-2015, 09:28 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It took me a while to find a shop that did siping too. What's surprising is how many tire shop managers had no clue what siping is or does. One manager even cluelessly asked me why I would want to cut up a perfectly good tire after I failed at explaining what siping was to him. Even pointing it out to him on some street tires in his store lobby.
Jerry Bransford is offline
post #3 of 22 Old 11-04-2015, 09:28 AM
ChrisHager
Administrator
ChrisHager's Avatar
I recently called DT inquiring about siping a set of BFG KMs as well. I was told they haven't done it in over a year - their siping machine was recalled and they never replaced it. Before that, I'd always sipe my tires.
You can always do it yourself. I've heard of people using razor blades or flipping the blades in a tire groover.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #4 of 22 Old 11-04-2015, 09:28 AM
12bravo8
Speedway.com, Eastwood and others sell a cheap tire groover so you could do it yourself, and take on that liability if you drive them on the highway.
Sawzall with a metal cutting blade works ok too.
http://www.amazon.com/Ideal-Tire-Groover/dp/B004AW7XYU
12bravo8 is offline
post #5 of 22 Old 11-04-2015, 09:45 AM
Jerry Bransford
Administrator
A tire groover is way different from a tire siper.
post #6 of 22 Old 11-04-2015, 09:48 AM
ChrisHager
Administrator
ChrisHager's Avatar
Agreed. If you flip the blade though and use the little prongs, I've heard that works.
Then again, I'm currently keyboard jockeying this knowledge. I've never done it.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 22 Old 11-04-2015, 11:15 AM Thread Starter
buddastrat
Just for the record, I will not being sipin' up my tires. No way, no how.... ha ha. I would let someone with good experience do it. While I can probably get a good bit more out of these original MTRs, I'll just get new ones. The new Kevlars look killer and have some siping. Will be better than these 9.5 year old tires. Also like the BFG KO2s which look great too...
post #8 of 22 Old 11-04-2015, 03:01 PM
mschi772
1997 XJ Cherokee
Anyone running a tire shop who doesn't know what sipes/kerfs are should be required to tell every customer that walks through their door that they are nothing more than a vendor with no knowledge/expertise. It's frankly pathetic that my tire knowledge can outclass that of most guys whose actual jobs are at tire shops while I'm formally educated as a biologist and a lake/prairie/forest restoration manager/tech by trade (and canine behavioral consultant on the side). Too often I find myself educating mechanics too unfortunately.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #9 of 22 Old 11-04-2015, 03:25 PM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
I buy my tires with enough cuts and grooves in them already.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #10 of 22 Old 11-04-2015, 03:31 PM
Fourtrail
1974 CJ6
Why not DIY? Set the blades shallow and go to town. You will wear the rubber down soon enough if you don't like the pattern you did. You will have to do something really wrong to damage a tire with a siper head in the end of the iron.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #11 of 22 Old 11-05-2015, 07:54 AM Thread Starter
buddastrat
I guess, I figure there's a science to it. Can't just be as simple as cutting lines in the treads. I wouldn't know the pattern or spacing, and there's no one way to copy. Might end up hydroplaning or something. Only thing I did read is to just do the center treads, not all.
Anyone have a good example of how to do it on the old Goodyear MTRs? I have read I only want to sipe in the middle row. Also, my tread depth is right at 4/32"'s (1/8). Is that too low for an MTRs? The older ones that came on the TJ Rubicons.
This would be a cool project and if I'm gonna get new treads anyhow...
post #12 of 22 Old 11-06-2015, 05:49 AM
KhakiKraken
I sell tires for a living. Tread siping is designed to allow for water to have a place to go to avoid hydroplaning. If you lay a dime on a tire, that is the distance that water will travel under pressure of the tire, so if you decide to cut your own siping keep that in mind.
KhakiKraken is offline
post #13 of 22 Old 11-07-2015, 08:27 AM
spbarone
2015 JK Wrangler
This debate is almost as old as studded vs studless snow tires. Most shops won't do aftermarket siping because it will void any warranty on the tire. There's a lot to be said about pros and cons and while it's true that siping generally improves traction, the technology in siping that maximizes that benefit is now a lot more complicated that just a straight cut in a tire - which is the best that any shop can do in the aftermarket. Straight cut sipes can actually destabilize the tread block, resulting in chunking, excessive heat buildup, and significant increases in braking distance. The reason that OE siping is so good (and possibly why shops are attempting to mimic it) is because most OEs are 3D sipes which actually create a firmer, more stable tread block under load while still providing the additional edges for improved traction and braking.
spbarone is offline
post #14 of 22 Old 11-07-2015, 03:24 PM Thread Starter
buddastrat
And that's why I won't try to do on my own. But my old MTR's, are stock from '06, and don't have any warranty issues. So I wanted to find some place to do it and maybe get another year out of 'em. No matter, they are worn enough and good excuse to get some KO2's that have lots of siping.
post #15 of 22 Old 11-08-2015, 06:48 PM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Buy a tire grooving tool and sipe them yourself. It's easy enough to do by flipping the blade over as some have already said.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
