tire recommendations for a JK - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > tire recommendations for a JK
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 08-24-2015, 02:24 PM   #1
Pnble09
2015 JK Wrangler
I am going to be putting a Terflex 3" lift on it, and throwing some 17" wheels/ 32" tires. I am wondering what a good A/T tire is for a vehicle with this setup? it will be 70% road/ 30% weekend warrior on trails in the backwoods. No rock crawling or mud bogging.
Pnble09 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2015, 09:45 PM   #2
Pnble09
2015 JK Wrangler
Anyone?
Unread 08-25-2015, 03:55 AM   #3
energeticmister
I highly recommend that you go for BF Goodrich All-Terrain T/A K02 Tires. They are the perfect on and off road tires.
2001 Jeep Wrangler Sahara
energeticmister is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 10:15 AM   #4
WXman
Your JK already has 32" tires if you have the Sport S or higher trim level. As far as a good AT tire...there are lots of options but some are slightly better for certain conditions than others. Is your part of Cali dry? If so, just about any AT tire sold today will be great. Sloppy conditions require certain tread patterns though. The KO/KO2 tread pattern generally sucks for mud and snow.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 02:46 PM   #5
Pnble09
2015 JK Wrangler
I don't have the sport S, I have 30's on right now. I live in Fresno, but I will bringing my yeep up to the mountains on trials and stuff through creeks and ****. So I want a tire that will handle well in those conditions
Unread 08-25-2015, 04:12 PM   #6
Pnble09
2015 JK Wrangler
I am also considering jsut going with mud tires. Someone told me that there are certain mud tires, that don't wear too much on the road and aren't too loud.
Unread 08-25-2015, 06:14 PM   #7
ezk83
I have a 2014 jku with a 2.5 teraflex lift and flat fenders. I run a 35" open country extremes. They ar all terrains and I love them.
ezk83 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 07:43 PM   #8
Pnble09
2015 JK Wrangler
Which ones are the extremes, this is toyo right? I see Open Country M/T,R/T, and A/T
Unread 08-26-2015, 07:11 AM   #9
WXman
The A/T they sell comes in three flavors... there is the normal one, the ones with even deeper tread, and then the "xtreme" version with wider void between the lugs. They are all the same tire...just slight changes to tread depth and spacing.
If you get, say, a 33x12.50 it's likely going to come in the xtreme version, but a P245/75-16 will just be the normal version.
Unread 08-26-2015, 11:35 AM   #10
Pnble09
2015 JK Wrangler
I was going to go with the KMC XD Rockstar II, but just looked around and got nothign but bad reviews when taken off road. so back to the drawing board.
