Tire Question, Very Easy - JeepForum.com
post #1 of 6 Old 05-19-2001, 02:35 PM Thread Starter
bigjeep39
bigjeep39's Avatar
Ok i was wondering what the most popular Super Swamper TSL tire is, are they good, do they wear to easily, also what would the back spacing be if i were to get 33" tires on 15x10 wheels.
1998 TJ
Slow steady project.
bigjeep39 is offline
post #2 of 6 Old 05-19-2001, 09:20 PM
Dustin Maschino
i dont know about the back spacing, but the most popular would probably be the Bogger or the SSR's...
and all super swampers wear easily....
Dustin Maschino is offline
post #3 of 6 Old 05-28-2001, 01:26 PM
osburn
osburn's Avatar
Lots of choices here! First, you have to narrow down whether you want to run bias or radial. The radials are going to be a better on road tire. The bias tend to flat spot overnight. In the morning you'll have to put 10 or so miles on them before they're round again. The other thing to consider is the air pressures you have to run in each. With the bias plies, you need to run less than 4psi in the tires off road to get any flex out of them for maximum traction. At that low of a pressure, beadlocks are almost mandatory. I run my SSRs 10-12psi and that's more than enough sidewall flex. The upside of the bias plies are their sidewall strenght. You probably don't need a spare because you just about "can't" cut a sidewall in these tires. They are the toughest.
Once you've decided between radial and bias, there's two radial TSLs to choose from and I think 3 bias ply TSLs.
Matt Osburn
Score 1032
osburn is offline
post #4 of 6 Old 05-29-2001, 03:16 PM
rayray
rayray's Avatar
well put oz.
bigjeep39,
FWIW, I've personally run the following..
Thornbirds: they suck! Plain and simple!
TSL/SX: awsome tire, but limited sizes
TSL: my favorite all around.
TSL/Radial: my choice if I drove my rig daily.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #5 of 6 Old 06-01-2001, 06:52 PM Thread Starter
bigjeep39
bigjeep39's Avatar
hey rayray i couldn't understand the lingo (oz) and (fwiw) but i will have to go with the tsl radial
Thanks To all
1998 TJ
post #6 of 6 Old 06-02-2001, 01:40 PM
rayray
rayray's Avatar
OZ = Matt Osburn
FWIW = For what it's worth
rayray
rayray is offline
Quick (easy?) amp question ace5ja Audio, CB & Ham Radios, GPS, & Electrical 4 05-09-2008 11:58 AM
Easy question Diehard Tires & Wheels 1 10-11-2006 11:27 AM
Easy question regarding Tcase Pottymouth Engines & Drivetrain 2 07-20-2006 10:50 AM
Quick Easy Question CherokeeLmt98 General Jeep & Off-Road Equipment 2 01-25-2006 06:36 PM
Tires??? Easy question, I think... cherokeeIVAN Tires & Wheels 8 03-18-2002 10:52 AM
