-   Tires & Wheels (http://www.jeepforum.com/forum/f15/)
-   -   Tire problems on a 2" lifted WJ... (http://www.jeepforum.com/forum/f15/tire-problems-2-lifted-wj-1698650/)
dryomz 10-18-2013 05:22 PM
Hey Guys and Gals,
I just did my first suspension lift on my 2004 WJ. 2" Rough Country lift and added 1.5" wheel spacers. I upped the tire size from my stock p225/75/r16 to Hankook Dynapro ATM p245/75/r16, and despite the little charts found on Jeepforum.com and reading various threads that indicated it would be fine, these tires rub on moderate turns.
Would you guys recommend a smaller tire? Raise the body a little higher? Perhaps the spacers are hurting the situation?
Fortunately I can exchange my tires for smaller ones at no cost, and I can return the wheel spacers if needed.
I can go take some pictures upon request.
I'm off to the bar :cheers2: hopefully Ill see some feedback in the morning (Im relatively a rookie at this, so go easy on me)
Thanks!!!!
Spud100 10-18-2013 07:52 PM
I'm kind of surprised you're having issues because that's not a huge size change. And the fact you added 1.5 spacers. Though I'm not familiar with WJ I would think you'd be in good shape. Have you determined what the tires are rubbing on?
DavisI 10-18-2013 11:09 PM
If the rough country lift consist of new springs or just a spring spacer? If it's just a spacer, your stock springs may have sagged, netting less than two inches
dryomz 10-19-2013 08:26 AM
Stock springs, here are some photos...
http://i.imgur.com/ibVidkp.jpg
http://i.imgur.com/eaCWAoH.jpg
http://i.imgur.com/NQCOHB1.jpg
http://i.imgur.com/rz1h4hh.jpg
jpat30 10-22-2013 01:16 PM
I have a WJ and run the same exact size tire you are but in a LT series. I run the OME HD lift.
#1 as previously stated, your stock springs and isolators may have sagged over time and resulted in you not getting the advertised lift
#2 take your spacers off, remount your wheels and check your clearance
#3 trim some of the plastic off of the front bumper. It is very easy to do; just take your time and remove a little at a time.
You should definitely be able to run this size tire with your BB though.
Hope this helps out.
The time now is 09:11 PM.
