10-30-2007, 12:48 PM
#1
Tire pressure / Chalk test
I know that this topic has been discussed over and over again but I had a question regarding the chalk test for getting the tire pressure set correctly.
I just put on a set of 35x12.5 Mickey Thompson MTZ.
This pic is the tire at 22psi. Looks over inflated so I took it down.
After doing the chalk test again, I end up running at 13psi. Does that seem low to anybody else?
2002 TJ Sport, Locked in rear. Armor dents and character.
05 WK 5.7L Limited. Stock...... for now.
Colorado Jeep Club Member #79
10-30-2007, 01:08 PM
#2
Way too low...IMO, the chalk test sucks. See this thread for a better formula...
http://www.jeepforum.com/forum/showt...ght=chalk+test
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
10-30-2007, 02:00 PM
#3
When I do the math that is suggested in that thread I come up with 15psi. Still seems kind of low.
Weight of jeep: 4450
Max psi on tire: 35
4450 x 35 = 155750
Max load on tire: 2535
2535 x 4 = 10140
155750 / 10140 = 15.35
Did I do that right?
10-30-2007, 02:03 PM
#4
Lets go Penguins!!!!
Yeah using the math formula I came up with something like 12 psi for my current combination.
10-30-2007, 02:05 PM
#5
JEEP FREAK
Yes, you did the math right.
You're going to have to air them up a little and deal with the uneven treadwear. 15 psi is too low for the street.
I'd continue to run them at 20-22 like you had them at previously.
10-30-2007, 02:07 PM
#6
Demonic Jeep Freak!
I've got the exact same tires on my 98'.My brother emailed MT about his 33's and they told him to run 22psi.I emailed them and never got a response.I've got 24psi in mine now and the side tread looks like it's 1/4-1/2" off the ground.I hate to go below 20psi,so I guess I'll see if someone answers your question.Sorry I couldn't help.I'm in the same boat
10-30-2007, 02:09 PM
#7
Thanks for the help guys. Looks like I'll air them back up to the 20 range.
10-31-2007, 06:26 AM
#8
Doesn't some of the wear depend on the width of the rim? I mean, with a 10" rim, the wear will be more even at 20-22lbs than it would be with an 8" rim at the same pressure. At least that's what I always thought.
10-31-2007, 06:51 AM
#9
JEEP FREAK
Yes, wheel width is a factor.
10-31-2007, 09:10 AM
#10
That may be what makes the difference. I am running a 15x8 rim.
10-31-2007, 09:21 AM
#11
Yeah, you'll get more bulge. I know I get good wear with my 33x12.5s on 15x8s and I run around 28lbs on the street.
10-31-2007, 10:42 AM
#12
For street use I always inflate to max pressure, my wear is even with rotation of the tires. Remington Wide Brutes 30 x 9.5 x 15
50 psi cold
10-31-2007, 10:49 AM
#13
JEEP FREAK
50 psi cold
How are you getting even wear running max psi?
10-31-2007, 10:53 AM
#14
Italian Wheeler in Mexico
50 psi cold
50 psi is the max psi cold for a single tire, it's waaaay to much pressure. And by the way it's unsafe. You are playing at the limit of your tire max pressure rating. For a 30x9.5x15 if it is a load C range (i guess so) you should aim at 30-32 PSI cold.
To the OP: i run my mtz at 20-22 PSI cold.
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
#15
Farm Wheeler
50 psi cold
The tread and sidewalls of those tires must have the same ability to flex as 1/4" steel plate.
