Quantcast Tire Pressure for 33x12.50 and Tire Size Question - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Tire Pressure for 33x12.50 and Tire Size Question
Old 05-12-2007, 02:30 PM   #1
blackout00
Hey guys have 2 questions.
1.What tire pressure do you run in your 33's for street use? Please let me know.
2. Will 35 x12.50 tires fit under my 00 TJ Sport with 3 " Teraflex Lift? I think I am fine but just want some other thoughts! As always, Thanks!
blackout00 is offline   Reply With Quote
Old 05-12-2007, 02:52 PM   #2
Jonny Jeep
Jonny Jeep's Avatar
tyre pressure depends on what tyres and the setup of your vehicle. you will get loads of answers. for example I run 18-20 psi street pressure in my 33" MTRs
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service
Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php
Jonny Jeep is offline   Reply With Quote
Old 05-12-2007, 02:54 PM   #3
$lick
30 psi on my BFG A/T 33 1250's and no 35s would not be logical with a 3 inch lift.
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline   Reply With Quote
Old 05-12-2007, 03:16 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
For 33" tires, 28 psi is a good street pressure that will insure your tires wear properly.
No, a 3" lift is not enough for 35" tires, not even close.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 05-12-2007, 03:21 PM   #5
BluesMan
33x12.5 BFG MT at 28. I have not chalked them yet to see if it's the best choice.
...Don't follow Chili Palmer into the trees...
BluesMan is offline   Reply With Quote
Old 05-12-2007, 06:04 PM   #6
TJafflicted
im @ 28 psi currently. id say 24-28 is a good pressure to try out..i will probably try 26 when im bored enough to mess with it.
2003 TJ - 4.0 - 5 speed - Fabtech front bumper - ORfab rear bumper - SYE - RE 3.5 lift - EGR flares - Ridgid toolbox - 33x12.5 Mickey Thompsons
1988 Samurai - 1.6 - 5 speed - 6" lift - lockrites front and back - 8000 lb. winch - 31x10.5 pro comps - 6.5/1 transfer case - onboard air - dual batteries - etc. etc.
TJafflicted is offline   Reply With Quote
Old 05-12-2007, 06:25 PM   #7
1BadJeepX06
I run 28 PSI in my 33" BFG's...
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline   Reply With Quote
Old 05-12-2007, 06:34 PM   #8
orangetj05
30 psi 33x12.50 bfg muds
2005 TJ Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
ORANGE JEEP MEMBER #8
orangetj05 is offline   Reply With Quote
Old 05-13-2007, 12:32 AM   #9
chobeegators
I just read in JP magazine that if you chaulk your tire then run it down the road a little ways you can tell if your over inflated, under inflated or at the right pressure. Depends on how the wear pattern is. Hope that helps.
chobeegators is offline   Reply With Quote
Old 05-13-2007, 01:43 AM   #10
Difranco
Pressure is going to depend on the make/model of tire and the weight of your Jeep.
http://www.jeepforum.com/forum/showt...=tire+pressure
Orange Jeep Club Member #13--Metalhead Jeep Club Member #13--Poseur Jeep Club Member #13
Gun Control: Means never having to say "I missed you!"
FOR SALE: OE Rubicon Shocks / OE Rear Bumper / OE 3rd Brake light / OE Front Trackbar / OE Rear Trackbar -- PM for details and make your best offer.
Difranco is offline   Reply With Quote
Old 05-13-2007, 01:49 AM   #11
dirtbagofva
2010 JK Wrangler
I run 24 in my MT/r's and physically 35's will fit but will rub off road. For pure street use, they will work but so does a Civic.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline   Reply With Quote
Old 05-13-2007, 10:37 AM   #12
blackout00
Thanks for all the good answers. I guess I am going to stick with 33" tires. I also am running about 28 psi in the tires now. Thanks again....keep them coming if you have more suggestions.
Old 05-13-2007, 12:36 PM   #13
OneCleanYj
I'm running 33" BFG Muds on 15X10's and I keep 'em at 30 PSI for the street and they're wearing excellent. Never done the chalk test but like I said they're wearing fine. I actually bumped 'em up to 35 PSI yesterday and it cruises awesome now. Gona have to chalk 'em though to see if it's affected the wear pattern.
92 YJ. Lifted, rubbered, geared, and more
OneCleanYj is offline   Reply With Quote
Old 05-13-2007, 07:46 PM   #14
blackout00
Great thread. Like the formula. I am running 28 now...seems a bit stiff. Going to go back down to 26 and see how that works. Thanks again for everything!
Old 05-13-2007, 08:14 PM   #15
CB3
My Answers:
1) I have 33 X 11.3 tires and by much testing and trial and error, I've established that they run best at 29 psi cold pressure tested in morning before driving. The local tire stores and also some online guys say they should run with 28 to 30 psi for my tires and vehicle weight (LJ Rubi). At 28 I get to much body roll. At 30+ it rides to rough. So 29 seems a good compromise for my 33 X 11.3 tires. Now your tires are wider, so I'd guess they run better at about 1 psi less than mine (just a guess).
2) I don't see how you could possibly fit 35 tires, unless you got the Highline Body Kit from AEV installed, which lifts and enlarges the fenders so that you can take 33" tires with no lift, 35" tires with 2" lift, or 37" tires with 3" lift, according to what users of that product have told me. Other than this kit, I don't see any way you're getting 35" tires on a Jeep with a 3" lift. AEV also sells wheels that are made to fit 35" to 37" tires on Jeeps with their Highline body kit and a 2" or 3" lift.
Also, the proper tire pressure partly depends on the relationship of wheel width to tire width. With an 8" wide wheel and a 33" x 12.5" tire, 28 psi sounds correct, but I run 29 psi cause my tire is 33" X 11.3" wide on an 8" rim.
If the rim were wider, say a 10" rim, then you could run a bit more pressure and still have a flatter foot print for better wear and street traction. So if you have a 10" rim with a 33 X 12.5 tire, then 30 psi, or perhaps even a bit more, is appropriate. The flatter footprint and higher tire pressure is why a wider rim in relation to the tire is better on street for street performance and fuel economy. This according to a couple of local tire stores in my area, and also what a wheel manufacturer tech told me on the phone.
However, the narrower rim holds a bead better when aired down off-road, as many at this very site have said many times.
We aren't making street rigs here, but I'm also not making a dedicated off-road rig either. I want the best all purpose, versatile, on and off road result. So that's one reason I prefer a medium width rim (like a 9" wide) cause then I can get a nice compromise between on and off road performance. Another reason I like a medium width rim is cause it suits my medium width tire preference (also for versatility).
Anyhow, the best tire pressure depends partly on tire size and vehicle weight. It also depends on the rim width, and depends on the load range of the tire. A higher load range tire on the same vehicle is a stiffer tire with stiffer side walls. So less air would probably be desirable when tire has a higher load range.
I think that for most Wranglers, a load range D tire is most appropriate. However, for anyone wanting the very most tear resistant sidewalls, then load range E. Personally, I'll stick with D because it rides smoother and is lighter weight than E. I don't care for load range C tires because I think the side walls are to wimpy even for trail use. However, my trails are wild. So maybe my view is skewed there.
CB3 is offline   Reply With Quote
Glock Forum
