Tire pressure on 33" goodyear mtr? - JeepForum.com
post #1 of 10 Old 10-18-2013, 03:35 PM Thread Starter
djdan42g
2010 JK Wrangler
Class d...17" wheels..mostly street driving..says 65psi max...Sounds too high.. I have no idea..shop says 65 to protect themselves..please help
djdan42g is offline
post #2 of 10 Old 10-18-2013, 04:24 PM
biffgnar
biffgnar's Avatar
26-28 area
biffgnar is offline
post #3 of 10 Old 10-18-2013, 05:30 PM
Eckoh
i have 35s on 15inch rims and i run 28 PSI.. i have 40k on them and still about 60% tread
Eckoh is offline
post #4 of 10 Old 10-18-2013, 09:08 PM Thread Starter
djdan42g
2010 JK Wrangler
Wow that low? I'm running way too high ..whats downside of too much pressure? Wear ..alignment? Thanks for the help
djdan42g is offline
post #5 of 10 Old 10-19-2013, 06:48 AM
biffgnar
biffgnar's Avatar
It will ride like a Fred Flintstone car and your tires will have excess wear in the middle of the tread.
biffgnar is offline
post #6 of 10 Old 10-19-2013, 06:58 AM
JPi1
Not more than 30
JPi1 is offline
post #7 of 10 Old 10-19-2013, 08:10 AM
WhiteOut
WhiteOut's Avatar
I'm running about 28psi as well. Down to 10 offroad, don't want to risk single digits without beadlocks.
WhiteOut is offline
post #8 of 10 Old 10-19-2013, 08:47 AM Thread Starter
djdan42g
2010 JK Wrangler
Thanks guys appreciate it
djdan42g is offline
post #9 of 10 Old 10-20-2013, 01:19 AM
Eckoh
i go to 6-8psi. but i also have OBA and 8 inch wide rims, its harder to unseat a 12.50 on an 8inch.
BTW when did they change the pattern of these??? mine are about 6-7 years old soi have what now seems to be the "military" pattern
Eckoh is offline
post #10 of 10 Old 10-27-2013, 11:26 PM
squarelite
I ran about 28 psi in my jeep. With 65 psi in it, take some chalk and color a section of tread the entire width of the tire. Take it for a short drive around the block. Then get out and look and see how much of the tire you are using. Then do the same thing with 28 psi and see how it looks. I was using all but about 3/4" on each side of the tread on a 12.50" width.
squarelite is offline
