tire pressure on 31x10.5 - JeepForum.com
post #1 of 5 Old 04-29-2004, 09:29 PM Thread Starter
tchfall15
I just mounted my 31x10.5 MTRs. What tire pressure should i have for onroad? All i drive is onroad. Just got the tires for looks. Thanks
tchfall15 is offline
post #2 of 5 Old 04-29-2004, 09:54 PM
xjj33p3r
xjj33p3r's Avatar
35 psi is standard for all tires
xjj33p3r is offline
post #3 of 5 Old 04-30-2004, 06:34 AM
Mels95YJ
Mels95YJ's Avatar
I wouldn't run 35psi in them. Look at the label on your driver's door frame. It will give you DC's recommendation. I believe it's like 30 front and 32 rear or vice versa. Personally, when I had 30's, I ran 30psi all the way around. That was the best "feel" I found. WIth 33's I run 28psi all the way around. HTH
Mel
Jeep with stuff.
Mels95YJ is offline
post #4 of 5 Old 04-30-2004, 08:32 AM
MSHarnett
Broke Bogger
MSHarnett's Avatar
I agree with Mel. You need to find a pressure that is good for you. You don't want it to high, cause you'll have a bumpy ride, to low and you'll wear the tire fast. I tend to keep mine right around 30psi. Sometimes I'll be a little more or less, like if I go someplace far with alot of wieght, I'll pump up to like 32. If its snowy or maybe even rainy for a while I might go as low as 25 and 20 in fresh snow, just to help with traction.
Matt
MSHarnett is offline
post #5 of 5 Old 04-30-2004, 08:33 AM
gigihurt
gigihurt's Avatar
Thirty five is not standard it all depends on the tire and weight of the vehicle. The tire will say the amount needed at full load on vehicle. My michelins on my suburban call for 46 at full load and I run at 38,The sand flea runs at 32 on highway and 19 in the woods.
gigihurt is offline
What is the correct street tire pressure and off-road pressure? JeepinYahoo Tires & Wheels 84 04-11-2013 05:52 PM
BFG ATs 31x10.5 what tire pressure? BradG Tires & Wheels 9 04-04-2007 11:18 PM
best tire 31x10.50 mfm22 Tires & Wheels 23 01-08-2007 06:49 PM
31x10.5 Kumho Mud tire pressure? thebulkinator Tires & Wheels 2 04-13-2005 09:01 AM
will a 31x10.50x15 tire fit on a 15x8 inch rim clinganc Tires & Wheels 1 04-03-2004 06:46 AM
