tire help - Page 2 - JeepForum.com
post #16 of 44 Old 12-03-2010, 02:35 PM
ajf1994
Yes. Your only problem might be with width. If you don't get new wheels, get a set of these. You will need to order two sets (two axles).
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #17 of 44 Old 12-03-2010, 02:37 PM Thread Starter
boogeyman
i have to order new wheels. i have lil stock steelies ha
boogeyman is offline
post #18 of 44 Old 12-03-2010, 02:38 PM
jabroni3411
I've heard spacers will loosen up and require constant re-tightening.
Check My Build
jabroni3411 is offline
post #19 of 44 Old 12-03-2010, 02:41 PM
ajf1994
jabroni3411: Not the spidertrax. They are hubcentric as oppose to lugcentric like the ones you find on ebay.
boogeyman: I suggest finding some stock alloys on craigslist. They are cheap, high quality, and look really good painted. Here's how I did mine.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #20 of 44 Old 12-03-2010, 02:47 PM Thread Starter
boogeyman
only problem is finding some around here. i really like pro comp wheels but they re about 110 a piece
post #21 of 44 Old 12-03-2010, 02:51 PM Thread Starter
boogeyman
and how hard is it to install a SYE?
post #22 of 44 Old 12-03-2010, 02:53 PM Thread Starter
boogeyman
also how good are the rubicon express motor mounts?
post #23 of 44 Old 12-03-2010, 02:54 PM
jabroni3411
you can always get some cheepie cragars at jegs.com for like 54 a piece to get you started. thanks for that heads up too on the spacers, first time ive heard the diff between the spider trax
Check My Build
post #24 of 44 Old 12-03-2010, 02:55 PM
jabroni3411
go with the bomb proof motor mounts from M.O.R.E, SYE is fairly easy when you get the whole kit together with a new shaft there are plenty of write ups about them on here check out the search tab
Check My Build
post #25 of 44 Old 12-03-2010, 02:55 PM Thread Starter
boogeyman
ill for sure keep that in mind but right now im collecting parts no rush. im only 16 ha
post #26 of 44 Old 12-03-2010, 03:02 PM
jabroni3411
Just remember a few things, if you upgrade something do it right the first time, twice as expensive and twice as time consuming to have to do it over again. If you change something most likely it'll effect another part or area so do your (jeep) homework prior and itll save you repairs in the future. Shop around too lots of companies out there offering deals and never look past Craigslist, junkyards and local shops with used parts
Check My Build
post #27 of 44 Old 12-03-2010, 03:09 PM
ajf1994
For motor mounts, I'd say to get this kit BL & MML from JKS, as it retains the factory bushings (it is just a spacer). If you want to get a full replacement go to the Brown Dog Offroad motor mounts, in rubber. If you get polyurethane, a lot more engine vibrations will be transferred to the body. I have never installed an SYE, and hope I don't have to. I want to stay relatively LCG, with no more than a 3" suspension lift and 1.25" body lift.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #28 of 44 Old 12-03-2010, 03:11 PM
jabroni3411
AJF u pumped about all that snow in Buff? im from Rome NY originally, sorry not to steal the thread
Check My Build
post #29 of 44 Old 12-03-2010, 03:16 PM
ajf1994
I didn't get any! I live in Clarence, North end of Erie County, and the school district a mile South of me was closed the last two days with 3 feet of snow, and we got an inch! It made me really mad.
-SupportOurTroops-
37,xxx Miles
ajf1994 is offline
post #30 of 44 Old 12-03-2010, 09:25 PM Thread Starter
boogeyman
can i just get the JKS spacers anywhere?
35" Tire + Rugged Ridge RRC Tire Carrier + Hi-Lift Jack Mount Joe2478 TJ Wrangler Technical Forum 2 08-20-2010 06:03 PM
35" Tire + Rugged Ridge RRC Tire Carrier + Hi-Lift Jack Mount Joe2478 JK Wrangler Technical Forum 1 08-20-2010 11:24 AM
Quick question (33" tire on stock spare tire holder) LuCk3e87 TJ Wrangler Technical Forum 4 01-09-2009 06:44 AM
31x10.5x15 wheel tire combo on stock tire carrier? ADIDAS TJ Wrangler Technical Forum 13 06-24-2005 11:20 AM
Moving tire jack to spare tire bracket? Whts everyone think about this item on Ebay? brewc TJ Wrangler Technical Forum 2 11-19-2004 07:08 AM
