#1 | |
tire deflators
i'm looking for reviews for staun or smittybily tire adjustable deflators
any advice thanx
#2 |
Not to hijack, but I think it's still relevant. I have no experience with those 2 you mentioned, but I use this:
http://www.quadratec.com/products/95202_410.htm Works FANTASTIC. Superfast, and reliable. -Ghan |
#3 |
the smity built ones are junk i have used the stauns and they never held a setting for me so i ended up going with the currie deflator
http://www.parksoffroad.com/prodreview/deflatortest/ezdeflate/ezdeflate.htm |
#4 | |
need to look for a new compressor this summer. |
#5 |
not to sound like a jerk:
but i don't understand why people feel the need to spend so much money on these things, you can buy a valve stem remover from Autozone for ~$1.25 and air your tires down in no time flat. (no pun intended) -John
needing a new rig.... |
#6 | ||
#7 |
i used the staun at penn's woods jamboree last year, it's nice to deflate to 12psi on all 4 tires at once
was looking to save $20 and go for the smittybilt but only found 1 reviews online (wasn't good either) |
#8 |
the stauns are nice but mine never held the pressure setting some would air down to 10 others to 18 and so on.....
#9 |
I use the Stauns and they work great, and fast. You just need to be careful that you don't move the setting once they're set. I haven't had them long, but they've continued to consistently get me down to 12 psi each time. Other than that, I went with them over the Smittybilt's because I read more positive reviews on them.
The have yet to (not) let me down. Yes, awful pun intended!
1980 CJ7 - Complete restoration (maybe finished someday) AMC 360, TF727 |
#10 |
I have the SB and they work like they are supposed to, after I took some000 steel wool and polished the internals and put a very light coat of silicone spray on them. I have used them at least 3x a month since i have worked on them and the times I have checked them afterward, my psi has been within 1-2 of each other. I usually run 11 in mine and drop from 25psi. Like others have said, just make sure you don't twist them by the large knob and knock them out of kilter.
99 TJ Lifted, Armored, & Locked, what else can I say??? I thought I was done with the mods..............I was wrong! _____________________________________________ One who refuses to grow up and is reliving his years as a "RecycledTeen" |
#11 | |
That's actually more work, and valve cores are easy to loose on the trail. If you remove the core, drain air, re-install the core, check pressure I will already be on the trail with my staun's. I can put them on at the gravel road to the trail,,,,and by the time I'm at the actual trail my tires are at 12 PSI. Unscrew the stauns and you're done till you want to air up. You can actually drive with the stauns on the tire. |
#12 |
Do it right or not at all
![]() Join Date: Jan 2003
I'm no fan of automatic tire deflators. I have tried several and they were never consistent enough to make me happy.
What I have been using for 4-5 years now that works so great is this one... you can get it from ARB or Currie. It is FAST because it removes the valve stem entirely. It also traps the valve stem internally so it can't be lost. I can deflate all four of my tires from 26-28 psi to 8 psi before most can do one tire using most common methods. ![]() Basically you screw the main part onto the tire valve stem, use the center knob to unscrew the tire stem, then pull the main barrel out and WHOOSH the air just DUMPS out. It probably takes all of 10-15 seconds to air a 35" tire down including checking its progress along the way with the pressure gauge. To check the air pressure as you go, just momentarily slide the barrel in and you get an instant air pressure reading. It's a great tool that I give two thumbsup to.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#13 |
I just never air back up.
no need to deflate that way!
Never trust anything that bleeds for 5 days and does not die! |
#14 | |
i'm fine with spending $1.25 and doing it that way, but like everyone says "to each his own". ![]() -John
#15 |
thats pretty much how i am now.....i aired down about 2 trips ago and just left them with around 12psi in them.....smooth riding!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
