Tire Chains - JeepForum.com
post #1 of 4 Old 11-22-2010, 01:22 PM Thread Starter
gbean120
Tire Chains
Why does rim size matter with tire chains?
Please excuse my grammar!
gbean120 is offline
post #2 of 4 Old 11-23-2010, 01:22 PM
06_LJCON
I need some more info? Do you mean rim width? ex(8", 9") or Diameter ex(15", 16")
The width should not matter at all the the wheel diameter will make a huge difference for this reason
For example if you have a LT265/70R16 and a LT265/70R17 The 17" tire is 1" taller in overall diameter and would then need a larger set of chains.
Not sure if this is what you meant but I hope it helps
(SOLD) 1991 wrangler 2.5L 5-Speed White, 2" BL, Warn rear bumper, warn winch, warn rock sliders.
(SOLD) 1987 wrangler 2.5L 5-speed BLACK!
S.O.A. with 4" springs and a 2" body lift. Lincon locked front. 33" TSL's NEED bigger tires!!
(WRECKED) 2002 Apex Wrangler 4.0L 5-Speed Silver
2.5" skyjacker single flex, skyjacker shicks, Rock Krawler adjustable lower control arms f/r, 1.25" JKS body lift, 1" JKS motor mount lift, JKS Quicker Disconnects, Warn engine/transmission skid plate, Rock Crusher Front diff cover, Poison spyder rocker knockers, 1.25 wheel spacers, 4.10 gears f/r, Detroit Trutrack rear, aussie automatic locker front
(CURRENT) 2006 Wrangler Rubicon Unlimited LJ 4.0L 6-speep, Silver, 3.5" Rubicon express lift with Rubicon express disconnects. Hella 500 lights, HID Bi-xenon headlights, Rock-It intake, Red top Optima, Factory MOPAR rocker knockers, TNTCustoms Front full tube fenders, 35x12.5R15 BFG KM2, Black steel wheels.
06_LJCON is offline
post #3 of 4 Old 11-24-2010, 04:35 AM Thread Starter
gbean120
My overall is 35 inch tire. But I have 18 inch rims. I was told that rim size matters because they don't want to scratch my rims.
gbean120 is offline
post #4 of 4 Old 12-03-2010, 02:10 AM
RockMonster
^^ bingo they will do a little more than scratch them if they are loose enough.
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
Tire chains le440 TJ Wrangler Technical Forum 11 01-20-2004 06:36 PM
tire chains badnews TJ Wrangler Technical Forum 1 08-26-2003 02:25 PM
Tire Chains SpitNine TJ Wrangler Technical Forum 2 12-06-2002 04:54 PM
Tire chains aboynamedmoose YJ Wrangler Technical Forum 2 11-08-2002 02:43 PM
Tire Chains Whybu1 TJ Wrangler Technical Forum 0 10-09-2002 11:24 AM
