thinking on some 33x10.50r15 - JeepForum.com
post #1 of 7 Old 12-27-2013, 08:04 PM Thread Starter
txgunner
I am new to the jeep world. I am going to start upgrading. I don't want big fat tires on it so I'm thinking about some 33x10.50 on it. Now first off, I don't do any wheeling, mudding, or rock climbing. It will be more of a daily driver sort of. It will be used on trails in colorado and new mexico. Most of what it will be in is mud from hunting, that will be it main job.
What do I need to fit the tires for what I'm doing. I am thinking about a 2.5" lift, and a set rims. Is it enough lift and what kind of backspace do I need on the rims.
Thanks
txgunner is offline
post #2 of 7 Old 12-27-2013, 08:27 PM
Spud100
3" minimum lift. 3.75 back space.
Spud100 is offline
post #3 of 7 Old 12-27-2013, 10:29 PM
Duck Doctor
What year and model jeep? I ran 33x10.5 tires on my TJ on 16x8 moabs with 5" backspacing. Tires didn't rub at full lock when turning.
Duck Doctor is offline
post #4 of 7 Old 12-27-2013, 11:02 PM
AntiPrius
I'd use no less than 4", and probably more like 4.5" BS for a 10.5" wide tire.
AntiPrius is offline
post #5 of 7 Old 12-28-2013, 10:32 AM
Ed209
For what you are doing, you don't need 33". You'll be wasting a lot of $ on a lift. All you need is a set of good mud tires. I drive around in the woods in a stock TJ with 31x10s.
Ed209 is offline
post #6 of 7 Old 12-29-2013, 08:31 PM
1993sahara
I run 33's on a 2" budget boost without rubbing. Wheels have 4.5" backspacing. Getting some new 33's in acouple weeks as well
93 Sahara 4.0, ax15, BDS 2 inch springs, MORE greasable 5/8hd shackles, Ford 8.8 rear, AA sye, Quigley cv shaft, 32" wrangler mtr with Kevlar
_____
/l ,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
1993sahara is offline
post #7 of 7 Old 12-30-2013, 07:03 PM
KKiowaTJ
1973 CJ5
That size nets you a couple choices. Being it BFG, They are actually a 32" tire so you could get away with 3/4" leveling spacers on it and a 1.25" BL. Its for mainly street and that will more than clear the tires.
As mentioned, A good set of 31" tires and leave it stock is a better option. You would be surprised what a jeep on 31's can do 4 or 6 cylinders. Use the extra $$ for a cheap winch for security. Good luck either way.
MOPAR!
KKiowaTJ is offline
