Is there a reference to find actual tire size versus stated size? - JeepForum.com
post #1 of 9 Old 03-10-2014, 01:09 AM Thread Starter
73azbronco
Any reference out there to find true tire sizes versus stated for the different brands of 33 or 35's?
Example, I have Toyo open country, they are stated at 35 inches, but measure a surprising 33.75 inflated to 30psi. Until I measured them, I would have sworn they were easily 35.
73azbronco is offline
post #2 of 9 Old 03-10-2014, 03:12 AM
JeepWranglerNation
Post Delete
JeepWranglerNation is offline
post #3 of 9 Old 03-10-2014, 10:57 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
No.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #4 of 9 Old 03-10-2014, 11:08 AM
mike_dippert
mike_dippert's Avatar
Actual size will vary depending on inflation, load, and wheel width. Easiest thing is to not worry about it. Second easiest thing is to find someone with a similar vehicle and the tires in question that has measured the actual size.
mike_dippert is offline
post #5 of 9 Old 03-10-2014, 11:10 AM
WXman
Rule of thumb I always use is take the listed diameter and subtract 1 inch. This usually works out great for tires under 35".
Remember, the manufacturer measures tires with the bulge of the sidewalls while mounted on a specific wheel included. You and I measure without the sidewall bulge. That's where the inch gets lost.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #6 of 9 Old 03-10-2014, 04:45 PM
Charley3
Look at tire height in mamufactirer's specifications. That's the height of tire when inflated to max psi.
But you won't be using max psi. So it will have less tire height.
Also perhaps what Wxmam said too.
Warning: I often edit my posts a few times to get them complete or correct errors.
Note: I had heart surgery Mar 2016. I wasn't feeling well since, but I improved this Dec 2016. Now I'm feeling better and getting back to Jeeping, modifying and wheeling.
Charley3 is offline
post #7 of 9 Old 03-11-2014, 06:05 PM
Scrmngchicken
Tire sizes are based on an inflated tire that is unloaded. Meaning not on a vehicle.
So no, there is no standardizing. Especially when dealing with different manufacturers. And when you factor in quality differences, it further complicates things.
Think of sizes as a guesstimate.
Scrmngchicken is offline
post #8 of 9 Old 03-12-2014, 10:54 AM
Ferrachi
I wasn't happy that a set of Duratracs I bought (31") measured out just a tad over 29". Wasn't what I expected at all and realized I had some researching to do. Use google, many other posts on this forum and others which talk about this.
http://www.jeepforum.com/forum/f96/a...specs-1206007/
Ferrachi is offline
post #9 of 9 Old 03-12-2014, 06:15 PM
mike_dippert
FOUND THE ANSWER!!!!
Look at the mfg's stated revs per mile.
20,168 / [insert rev's here] = more realistic actual size.
For example, your tires (MT's?) have 596 rev's per mile, which equals 33.8". Much closer than the 34.8" inflated diameter spec.
and yours are 681 revs, which is 29.6"
A 35" circle has 576 rev's per mile.
A 33" circle has 611 rev's per mile.
A 31" circle has 650 rev's per mile.
I've found that most 35" tires are in the 595-605 range.
33's are mostly in the 630's.
I'm not sure about 31's.
I haven't looked into it, but I believe the discrepancy comes from load bearing. The inflated diameter spec is the tire inflated to maximum psi, with no load. Revolutions per mile is probably the tire at it's maximum psi and load, meaning the tire has it's flat spot at the contact patch resulting in a shorter radius to the ground (which is half the functional diameter of your tire).
Hope this helps someone.
