Quantcast There has to be a way to fix this.. - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > There has to be a way to fix this..
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 05-15-2008, 05:35 PM   #1
Stout95YJ
2003 WJ
Fixing a slash in sidewall?
I was wheelin tuesday and popped a hole in my 33x10.50 MT
A new tire arrived here today from Tire Rack(180$ shipped) and Iwas thinking of using the popped on as a spare, is this repairable?
The cut itself is less than 1/2 inch
2003 WJ 4.0 - 2" BB - 255/75 on 17" JK Moabs - Projector's with 6000k HID's - 236k and counting
1996 XJ trail rig - sold
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." - Jeremy Clarkson
Stout95YJ is offline   Reply With Quote
Old 05-16-2008, 02:43 PM   #2
Freefly TJ
Most tire people will not suggest this or install it for you but I have a 33" MT with a side wall cut and I just put a tube in it. I thought I would never really need it until one morning when I came out to find my jeep sitting rim on ground. I ran the tubed spare for a few days to work and back (100+ miles) until I got my other tire fixed and it ran great. The key is to find someone who will put the tube in for you or do it yourself if you have the ability.
Freefly TJ is offline   Reply With Quote
Old 05-16-2008, 03:22 PM   #3
HoosierDaddyTJ
Tire Fix
I worked at a tire retread shop and we'd fix that sort of thing all of the time. We did mainly semi truck tires but I don't see how that'd be any different. Not good enough for everyday use but to use the tire as a spare any retread shop could do it for next to nothing ($20-$35). They will grind that whole place out and refill it with rubber and cook it in the tire oven. Easy fix if you can find a retread shop.
Anything worth doing is worth doing right.
I wave at other Jeeps and get my feelings hurt if they don't wave back.
99 TJ 4.0L ALL BLACK, 2 in RE BB and 32X10.50 Super Swamper TSL Radials
HoosierDaddyTJ is offline   Reply With Quote
Old 05-17-2008, 08:34 AM   #4
Happy Joe
If the cut does not extend to the sidewall cords I would just drive it.
If the tire leaks air, at the cut, then have a boot (large hot patch) installed inside the tire. If the cut extends through the sidewall, it will probably, eventually, pinch a hole in any tube installed without the boot.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline   Reply With Quote
Glock Forum
