the tallest 37" tire - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > the tallest 37" tire
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsSave at JeepHut on Smittybilt Soft tops
Unread 06-19-2014, 09:33 AM   #1
joe_jeep
i just got a set of 12/37/17 bfg km2s. they are about 36".
im kinda underwhelmed with their size.
who makes a 37" that is actually 37".
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline   Reply With Quote
Unread 06-19-2014, 10:00 AM   #2
biffgnar
biffgnar's Avatar
I don't understand the obsession with whether tires run true to size. First, I'm not convinced everybody measures them the same so opinions differ as to which do and dont. But more importantly in almost every case, regardless of advertized v. actual, a 33 is bigger than a 31, a 35 is bigger than a 33, a 37 is bigger than a 35, etc. and each step up proportionately (exponentially? ) increases the load and wear on the other components of the jeep. Pick your tire size and build your jeep based on what you need not what number is on the side of the tire.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 06-20-2014, 04:39 AM   #3
CJ7nvrstk
Every tire I have ever used has run short!
Toyo
BFG
Goodyear
Interco
Pro Comp
Ground Hogs
If you want a true 37, buy a 38 or 39!
The Cooper AT3 is a "hardcore AT" that "is the definition of aggressive"! Alrighty then!
CJ7nvrstk is offline   Reply With Quote
Unread 06-20-2014, 11:17 AM   #4
AntiPrius
Some are worse than others though in this regard. When I bought my Jeep it had brand new Big O XT's, that were supposed to be 33x12.5x15, but they looked like 32's. My new 33" Hankook Dynapro MT's are huge in comparison. It looked like I went up one whole tire size. The Hankooks probably don't quite measure 33", but the crappy Big O's were a solid inch smaller. I remember measuring them on the Jeep when I first got it and they measured under 32, about 31.5".
AntiPrius is offline   Reply With Quote
Unread 06-20-2014, 01:33 PM   #5
joe_jeep
my 35" old style mtrs were awful close to being 35" tall, on an 8 inch rim, at 25psi.
mabey my bfgs will grow when i put them on a rim. i was not happy how short they were.
i guess i got really bad *** 35"s for super cheap, basically.
glfwda #6624
Unread 06-20-2014, 03:52 PM   #6
SLADE
BFG's are known for being small in comparison to other tires of the same labeled size. Just another quality feature of one of the most over rated tire manufacturers.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote
Unread 06-23-2014, 05:57 PM   #7
johendley
Lol. Truth right there.
johendley is offline   Reply With Quote
Unread 08-26-2014, 06:53 PM   #8
joe_jeep
I like the size of the 11x38.5 bogger, but hate the tread pattern, and want a radial.
glfwda #6624
Unread 08-26-2014, 07:45 PM   #9
SLADE
I wouldn't mind seeing a narrow radial in the 37" range.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread 08-27-2014, 12:58 PM   #10
billiebob
When you get real tall and skinny radials do not have the structure to be stable.
Hence tall skinny tires are bias ply with a lot more structure in the sidewall.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote
Unread 08-28-2014, 04:39 AM   #11
mschi772
mschi772's Avatar
1997 XJ Cherokee
Agreed. What does it matter if a 37 only measures like 36.3? It's still bigger than a 35 (which probably only measures 34.x) and smaller than a 40 (which probably only measures 39.x). Is your whole Jeeping experience really dependent upon fractions of an inch of rubber?
mschi772 is offline   Reply With Quote
Unread Yesterday, 11:32 AM   #12
Charley3
I agree with everything you said, but don't you know that...
Tire size is a way for hetero men to (indirectly) compare penis size without having to look at each others' junk.
Thank God for big tires because it allows indirect comparisons.
Warning: Sometimes I edit a post a few times to get it how I want it.
Charley3 is offline   Reply With Quote
Unread Yesterday, 07:05 PM   #13
KKiowaTJ
I always make sure mine are true or as close to size as I can, Mickey Thompson and Goodyear have been able to provide that.
You have to factor in real life tire size and weight. If not, Then id be F'D if I built for a 36" tire, Bought 36-13.50-15 bias iroks, And soon found out the are as light as a 35" tire at 66lbs and measure out to a 37", 36.8 to be exact.
Best thing I have found, If you want to run 33's, Build for 35's. You will end up there anyway and or on 1tons in the long run.
YJ, TJ, XJ, ZJ..... Too many Jeeps!
KKiowaTJ is offline   Reply With Quote
