Suspension lift for 1994 wrangler - JeepForum.com
post #1 of 3 Old 06-01-2001, 07:58 PM Thread Starter
wags640
hi myname i joe anfd ihave a 1994jeep wrangler 2.5 liter 4 cylinder. It has an autmatic transmision. i was wondering ifi put a 4 inch lift and greaseable shackles on the jeep t fit 333 inch tires, would the 4 banger be eough? wht could i do to make the bigger tires work with the 4 banger? myb new ring and pinion. Any help will be greatly appreciated. thanks, joe.
Joe Wagner
wags640 is offline
post #2 of 3 Old 06-02-2001, 02:48 PM
rayray
rayray's Avatar
Joe,
I run 33's with a 4 banger and 4.56 gears. It's not a bad setup, but a tcase reduction kit will make it great. At least that's where I'm heading. One significant thing I have noticed is the differance that tire weight makes. On the road, when I ran BFG AT's, the jeep would have plenty of power. When I went to the same size tire, but swamper bias ply, on a narrower rim, power on the road sucked. Just something to think about.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #3 of 3 Old 07-05-2001, 02:10 PM
batman
I have a 1994 Wrangler 2.5L and want to put 33's on it also. After talking with many people I found that 4.56 would work, but while you're changing ring and pinion you mine as well put on 4.88 to put less strain on the engine and with a 4 banger you need all the power tou can get.
94 YJ 2.5L, 4" superlift, 33" Radial MT, wet okole seat covers, Sunrider soft top, front and rear light guards, billet grill, clarion cd player, 2-10" RF subs, soundbar, tb spacer. Thats all I can afford with school.
batman is offline
JK - Rubicon suspension replacement for Wrangler X gmlawrence Tires & Wheels 2 11-29-2007 09:07 PM
97 wrangler suspension diagram... smileyjeep Tires & Wheels 4 08-23-2007 03:59 PM
4" suspension lift on a '97 Wrangler Rednkgrl513 Tires & Wheels 4 07-04-2007 12:15 AM
Suspension lift vs suspension travel? Z0RR0 Tires & Wheels 2 03-08-2007 09:26 AM
Wrangler suspension noises DieTrying Tires & Wheels 4 07-26-2005 02:22 PM
