Stock Rubicon JK rims & tires on my TJ - JeepForum.com
post #1 of 38 Old 12-12-2009, 12:15 AM Thread Starter
comaddmax
Junior Member
comaddmax's Avatar
I'm getting my son's rims and tires off his Rubicon. What depth of adapter do I need?
comaddmax is offline
post #2 of 38 Old 12-12-2009, 12:26 AM
jdub2k5
shouldnt need an adapter
actualy arent they a different bolt pattern?
2004 TJ 4.0 5 speed, 2 inch body lift, barricade armor, 4.5 bds lift, 35 mtz, sye, and tons more
jdub2k5 is offline
post #3 of 38 Old 12-12-2009, 01:10 AM Thread Starter
comaddmax
Junior Member
comaddmax's Avatar
Yes, they are different, the TJ is 5X4.5 and the JK is 5X5.0 The tire size is also 32" diameter. The back spacing for the TJ vs the JK would determine the spacer depth.
post #4 of 38 Old 12-12-2009, 05:00 AM
JeepDoo
You will need a 5x5 to 5x4.5 adapter. Other than that you should be good. I dont think JK wheels have more than 5" backspacing, which is what Tjs are stock. So they should fit.
Hey hey, my my. Rock and roll will never die. - Neil Young
We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson
Longboard Drunk, Jeep Naked, Ski Powder
and finish calculus homework
JeepDoo is offline
post #5 of 38 Old 12-12-2009, 05:07 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
They come in 1.25".
Search Results - Quadratec
TheBoogieman is offline
post #6 of 38 Old 12-12-2009, 07:31 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
http://www.jeepforum.com/forum/f15/w...t-size-640000/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 38 Old 12-12-2009, 07:47 AM
Bennettj13
Jk rubi wheels are 17" wheels, are 7.5" wide, and have 6.5" of backspacing. A spidertrax 1.25" spacer will still end up giving you more backspacing than a stock tj wheel.
I run the jk wheels on my tj, but I swapped jk axles in too. The wheels are a pain in the *** now. I can't imagine them on a stock tj.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #8 of 38 Old 12-12-2009, 11:52 AM Thread Starter
comaddmax
Junior Member
comaddmax's Avatar
Can you elaborate on why the tires are a pain in the ***
post #9 of 38 Old 03-04-2010, 11:43 PM Thread Starter
comaddmax
Junior Member
comaddmax's Avatar
Bennettj13 are u still alive???
post #10 of 38 Old 03-05-2010, 02:46 AM
RogueSpear2023
Your probably going to either need a body lift or a suspension lift of some kind to fit 32s, 31s are the largest you can fit stock with out rubbing.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #11 of 38 Old 03-05-2010, 06:06 AM
98GP
I am running a BDS 3" kit and a set of wheel adaptors from A-DAPT-IT USA. The wheel adaptors are 1.30" thick.
[/IMG]
98GP is offline
post #12 of 38 Old 03-05-2010, 07:53 AM
Bennettj13
Sorry bro, Im a busy boy. the wheels have a buttload of backspacing. Running jk wheels with no spacers gets my tire all up into my swayloc arm. I would imagine the same would happen with the stock swaybar. I really don't know how it is done with a tj width axle. I've got the extra width of my jk axles and I'm still getting into everything. I am currently in the market for 2" spacers. That will make things a little more manageable. Good luck.
post #13 of 38 Old 03-05-2010, 08:13 AM
JTruel
The JK Wheels I measured had a backspacing of 5 and 7/8ths. Add a 1.25" adaptor and you get 4 and 5/8ths backspace.. no problem running them with the stock 255/75/17s.
2000 XJ Classic
2005 LJ
JTruel is offline
post #14 of 38 Old 03-05-2010, 07:40 PM
Bennettj13
I'm running a 12.50 wide tire, which is partly where my issues stem from. The other part is the fact that I've got some crazy aggressive tires, and the side lugs like to grab things, hence the Swayloc comment above.
post #15 of 38 Old 03-24-2010, 11:22 PM
r6less
Mine fit just barely. I have maybe 2 inches clearance at full lock.
How long did you have to wait to receive your adapters?
r6less is offline
Upgrade stock tires/rims with larger stock tires/rims (08 Wrangler Unlimited)QUESTION makstuss JK Wrangler Technical Forum 3 02-20-2011 05:23 PM
Rubicon Moab Rims on stock TJ Vinrod TJ Wrangler Technical Forum 12 11-16-2009 09:44 PM
Rubicon Take Off Tires/rims ARTSBEST JK Wrangler Technical Forum 12 03-10-2008 10:49 PM
Larger tires on stock rubicon rims Pinebarrensboy TJ Wrangler Technical Forum 5 05-28-2007 10:04 AM
how wide are the stock rubicon rims 03rubiconMG TJ Wrangler Technical Forum 1 09-18-2006 06:21 PM
