Steering Stops with Larger Tires - JeepForum.com
post #1 of 4 Old 07-08-2001, 02:09 AM Thread Starter
-D-
I just replaced some P225/75/15's with Pirelli Scorpion A/T's (30x9.5/15) on a '95 YJ Rio Grande. I went with 30's because I heard that 31's would rub on full steering. However, I found that the Pirelli's barely touch the bracket holding the leafs together (what are those called anyway?) when I crank the wheel fully over. Right now my fix is to not turn the wheel to it's full swing (not even a quater turn less is needed to make it not touch). However I'm thinking that in the future I'll install a lift (2.5" - 3") and run some bigger tires, will I have to fix the steering stops then to prevent rubbing?
also:
I thought 30's weren't suppose to rub? does it depend on brand?
and:
Does anyone have any feedback about Pirelli's? I can't say I've heard good or bad about them the guy at the store said they were good and I got them for over $30 cheaper then BFG A/T's each.
Thanks
-D-
-D- is offline
post #2 of 4 Old 07-08-2001, 11:03 AM
Tonka
2015 JK Wrangler
Pirelli's are good for the money, but as compared to the BFG's, the BFG's have a better overall design(for example a 3 ply sidewall, instead of a 2 ply sidewall)
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 4 Old 07-08-2001, 02:24 PM Thread Starter
-D-
Thanks, I was wondering about the difference between them. I got a pretty good warrenty plan through the company though (Americas Tire Store) they said they would replace them if I took any road or trail damage and he specifically mentioned ripping up the sidewall or taking a gash from a rock or street curb.
Do you have any thoughts about the rubbing though?
-D-
-D- is offline
post #4 of 4 Old 07-15-2001, 03:08 AM
Tonka
2015 JK Wrangler
Americas tire is Discount tire elsewhere in the U.S. I work for them in Dearborn, Michigan
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
buying larger tires and wheels rickyjames Tires & Wheels 6 11-11-2009 01:17 PM
Wheel wieght and larger tires ?? Gav'spurplez Tires & Wheels 11 04-29-2007 08:15 AM
question about larger tires/rims basso4735 Tires & Wheels 6 09-02-2006 10:23 AM
Tires and steering stops? BumbleBeeTJ Tires & Wheels 3 11-08-2004 07:26 PM
Odometer with larger tires?? Nymisus Tires & Wheels 7 10-23-2003 07:05 AM
