Steel or Alloy Wheels - Page 5 - JeepForum.com
post #61 of 84 Old 03-16-2011, 10:04 AM
ForumKing
Originally Posted by Ross View Post
I ran 3.73 with 33's for a while and it sucked.
Auto or Manual?
ForumKing is offline
post #62 of 84 Old 03-16-2011, 10:08 AM
Ross
Originally Posted by ForumKing View Post
Auto or Manual?
Manual, auto probably wouldn't be as bad.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #63 of 84 Old 03-21-2011, 01:01 PM
willydigger
Comparing a Pro-Comp 7069 Alloy at 16lbs and a Cragar 397 Soft 8 at 28lbs (both 15x8), will you notice any savings in MPG?
I would assume tire balance would be much improved also (considering a 50lb tire)?
Breaking?
I assume everything would improve, but would it be noticeable?
I'm looking to justify spending $100 per wheel compared to keeping my existing steelies.
NOTE: Regarding weight, I looked up the weight on Amazon. It should be close to accurate.
willydigger is offline
post #64 of 84 Old 03-21-2011, 01:05 PM
Imped
Imped's Avatar
I went from Cragar soft 8's to Black Rock 909 alloys. The weight difference was the same.
Improved balance--YES, much. Took much less weight and stay in balance. It's amazing.
Braking--YES.
Acceleration--not much of a difference.
MPG--maybe, but not much of a difference.
It's well worth it.
OlllllllO
IndyORV
Imped is offline
post #65 of 84 Old 03-21-2011, 01:15 PM
PeeWeeHerman
I just bought 5 pro comp 7069's from jcwhitney for 450 shipped. I think that is a great deal for alloy wheels.
PeeWeeHerman is offline
post #66 of 84 Old 03-21-2011, 01:30 PM
Deacon
Shining Adonis
Deacon's Avatar
Alloys all the way. There really is no advantage to running steel wheels, except the cost.
There are lots of rationalizations being thrown around, but this is the simplest, best way to put it.
And even if the alloys are $50 more per wheel, you're talking what, $250 difference including a spare, for something that'll make a positive contribution every time your Jeep moves? The cost incentive is just NOT there when you think about it. If you honestly can't afford it, you should be looking at a different hobby or developing some Zen-like levels of patience. Save and get the alloys.
Deacon is offline
post #67 of 84 Old 03-21-2011, 04:05 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by Knuckelhead View Post
Everything the same, I found about 10 lbs per rim...
I found 12 lbs per, when going from D-hole steelies to Procomp 1079s. Same tires.
BlueFlame is offline
post #68 of 84 Old 03-22-2011, 06:46 AM
Ross
I have gone from alloy to steel back to alloy. I can't tell **** for difference when driving. The alloys are easier to balance. My only advice is if you wheel don't my 10 inch rims (bead locks may be different).
Ross is online now
post #69 of 84 Old 03-22-2011, 07:13 AM
MountainMan864
Anyone got specs on weights of different brands alloy wheels, pref. a soft8 style, or teardrop cut.
MountainMan864 is offline
post #70 of 84 Old 03-22-2011, 10:43 AM
srmitchell
My Moab rims and 265/75/r16 All Terrain retreads weigh 80 lbs together.
Im hoping to go to a lighter tire soon.
I work on Mopars
srmitchell is offline
post #71 of 84 Old 03-22-2011, 08:36 PM
TurboTPI
I just went from stock early 90's xj aluminum wheels to steel D style. Same tires, I actually found the steel wheels to feel smoother over rough roads. Besides that, no difference. I am a fan of aluminum wheels tho.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #72 of 84 Old 03-22-2011, 10:21 PM
Deacon
Shining Adonis
Deacon's Avatar
I'm not sure what you're asking for, but I love my Mickey Thompson Classic II's... My 15x8's weigh 17 pounds a piece and make plenty of room for my 12.5" wide 35's without requiring spacers or any of that jazz.
Deacon is offline
post #73 of 84 Old 03-24-2011, 06:13 PM
Dirty Backroads
Dirty Backroads's Avatar
Originally Posted by samger2 View Post
I went from alloys to steel on my TJ. The reason I did that is because the alloys were so much harder to keep clean and not have the blemishes show up. I spent hours on my Mickey Thompson alloys trying to get them to shine again...whereas my cragar soft 8s clean up quickly and easily.
Alloys just require alot more maintenance to stay looking good.
Not if you get black painted alloys, like the Pro Comp 7069s. There are many black alloy wheels to choose from and many are quite affordable so you can have the best of both worlds. You aren't limited to just polished alloy anymore. I agree the polished alloys are horrendous to keep up with.
Originally Posted by 2005X View Post
i went from Crager soft 8 15x8 27lbs to procomp alloys 15x8 15lbs per wheel. while searching for alloys there are wheels out there that only weigh 7-10lbs
http://www.4wheelparts.com/Wheels/Xtreme-Alloy-Series-7069-Flat-Black.aspx?t_c=11&t_s=210&t_pt=100073&t_pl=101930& t_pn=PXA7069-5865
I thought the Pro Comp 7069s were 18lbs each? Pretty lightweight but not even close to 7-10lb wheels.
My race car didn't have wheels that lightweight! At that weight you risk bending a wheel.
You do better to shop here: http://4wheelonline.com/Pro_Comp_Wheels_7069_Flat_Black.142078.498905
I just bought a full set of Pro Comp 15x8s at $96/wheel.
Stay away from the polished aluminum wheels unless you like buffing and cleaning them constantly. The salt and dirt from the winter finally did my 1069s in. I gave up and just got the 7069s. Basically the same wheel in painted flat black.
Definitely go with alloys. I did some serious rock crawling with my Pro Comp alloys and never bent or cracked a rim. They don't leak. If anything the steelies tend to bend and leak and are harder to balance. Plus that extra unsprung weight is not something you want if you aren't regearing and going to 33s.
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #74 of 84 Old 03-24-2011, 09:51 PM
critterjeep
i'm about ready to just go back to my stock moabs. i have recently had a terrible experience with aftermarket rims. 550 bucks down the tubes.
2003 Rubicon (shale green/khaki), 33x12.5x15 BFG Mud KM2s on Pro Comp 8179s (Firestone Winterforce on stock Moabs for winter), Bilstein 5100s, 3" AEV (nth) Progessive coils, OME steering stabilizer, 1" M.O.R.E. body lift, JKS adj. track bar in the front, 1" JKS budget motor mount lift, RC quick discos, OR-Fab rear rock crawler bumper with 2" receiver, Rokmen 3/16" steering box skid plate, Rokmen rear frame tie-ins, Teraflex 3/16" heavy-duty oil pan skid plate, Alpine CDE-124SXM CD/sat radio MP3 player, Bestop sliding windows, Bestop Safari Bikini top (green military camo), Mopar "windjammer" rear window, Mopar "duster" tonneau cover with tailgate bar, Rockhard Full roll cage with full padding, KC slimlites long range/off road lights on KC windshield mounts, Tuffy security glove box, Pilot LED tail lights.
critterjeep is offline
post #75 of 84 Old 03-24-2011, 09:56 PM
2005X
yeah the ones i got weigh in at 15-18lbs. might wanna reread what i wrote, i said while searching there were some that weighed around 7-10lbs
2005X is offline
New wheels, Steel vs. Alloy bottlerocket91 TJ Wrangler Technical Forum 8 12-25-2010 09:49 PM
Wheels for offroad use, Steel or Alloy Rubydak JK Wrangler Technical Forum 39 04-10-2010 12:01 AM
Difference between steel and alloy wheels? mpo JK Wrangler Technical Forum 14 12-20-2008 10:40 AM
Wheels: Steel vs Alloy Evil_Trolloc Wrangler General Discussion 10 12-11-2008 06:56 AM
Difference Between Steel and Alloy Wheels? Avor TJ Wrangler Technical Forum 12 02-12-2004 10:26 AM
