Steel or Alloy Wheels - JeepForum.com
post #1 of 84 Old 03-08-2011, 08:31 PM Thread Starter
RemoteTrax
I am new to the Jeep world and am learning a lot by reading comments on this forum, thanks.
I put a 3.25" lift on my TJ and wanted to go with 33" tires. I have a Dana 44 with 3.73 gears, 4.0 with 5 speed. Still researching tires and wheels.
1) If I go with 33" tires, will I loose significant power? Looking at Goodyear Duratracks.
2) Steel wheels seem to cost about half of an Alloy wheel but I understand Steel weighs considerably more. Is it worth the extra cost for Alloy wheels in order to keep the extra weight off? Looking at ProComp.
I spend time in the mountains, on non-maintained roads, crossing creeks, over small downed trees and branches. I would like to try some rock crawling in the future but probably not a regular thing for me.
I would appreciate the advise.
RemoteTrax is offline
post #2 of 84 Old 03-08-2011, 08:49 PM
freeskier93
Weight difference will make a difference. 3.73s with 33s isn't going to be the best, but it's a lot better than 3.07s and will work. I always suggest just to try it out and see if you can take it since it's not going to hurt anything. If you just can't stand it then re gear.
Steel wheels will also bend, if you play in the rocks they'll probably get bent up. Alloy won't bend, but it will crack if you beat them hard enough.
freeskier93 is online now
post #3 of 84 Old 03-08-2011, 08:52 PM
The_Blacksmith
1993 XJ Cherokee
alloys tend to leak more, go steel.
Thanks Chris!
The_Blacksmith is offline
post #4 of 84 Old 03-08-2011, 09:08 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
You'll need 2" front and rear bumpstop extension to fit 33s with that lift. If you add a 1" BL, you can go to 1" front bumpstop extension and 1.25-1.5" rear.
yes, you'll want to regear to 4.56s for your 5-speed.
I lost 21lbs per wheel going from 31's on steel Soft-8's to 33s on Procomp alloys. The extra cost is definitely worth the lower weight & less chance for wobbles, and a tire thats easier to balance.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 84 Old 03-08-2011, 09:09 PM
litlmeck
Can you provide a link with to proof to that statement?
litlmeck is offline
post #6 of 84 Old 03-08-2011, 09:12 PM
vtx531
21lbs per wheel??? A 15x8 steel soft-8 only weighs about 27lbs total.
I would get aluminum wheels for my next wheels but I don't like the backspacing on them. They all stick out more than I like.
vtx531 is offline
post #7 of 84 Old 03-08-2011, 09:20 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
It's closer to 10 lbs per rim...IIRC
Knuckelhead is offline
post #8 of 84 Old 03-08-2011, 09:21 PM
wushaw
Rockin jeep
wushaw's Avatar
I like alloy. It's a personal choice.
wushaw is offline
post #9 of 84 Old 03-08-2011, 09:24 PM
Unlimited04
What's really interesting:
31s:
Steelie 16x8 Soft-8 wheels = 37 lbs
245/75R16 BFG AT = 48 lbs
Total: 85 lbs.
33s:
Procomp 1069 15x8 wheels = 16 lbs
33x12.50R15 Duratrac = 48 lbs.
Total: 64 lbs
Thats a 21 lb savings between each tire/wheel assembly, and 84 lb savings between all 4 rotating tires. Including the bald 33x12.50R15 BFG AT spare, thats a 100 lb savings moving from 31s to 33s.
Like I said - 21lbs per wheel.
from: http://www.jeepforum.com/forum/f9/un...ml#post9731094
Useful Write-Ups:
Funny:
post #10 of 84 Old 03-08-2011, 09:27 PM
PGH_JEEP
I went from steel to alloy, if you spend the majority of your time on the street the lighter alloys will definitely be the way to go especially if power is a concern.
PGH_JEEP is offline
post #11 of 84 Old 03-08-2011, 09:29 PM
vtx531
From 16" load range E tires to 15" load range C - yea ok.
Kind of misleading people though and most people should only expect to save about 2lbs per wheel if switching from steel to alloy and keeping everything else the same.
vtx531 is offline
post #12 of 84 Old 03-08-2011, 09:34 PM
Knuckelhead
AFSOC Retired
Everything the same, I found about 10 lbs per rim...
post #13 of 84 Old 03-08-2011, 09:34 PM
dcope17
If you decide to go steelies... Black rock is an american made wheel actually here in Ontario, California. Prices are similar. I don't know about buy I assume, and maybe i'll look like an a**, everything that says procomp is from China...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #14 of 84 Old 03-08-2011, 09:35 PM
Unlimited04
inaccurate assumptions on your part does not constitute misleading on my part.
Useful Write-Ups:
Funny:
post #15 of 84 Old 03-08-2011, 09:42 PM
hustler905
I had a similar experience to Unlimited04 when I went from steel wheels to alloy. My 35" BFG KM2's on alloy rims are a half pound lighter than the outgoing 33"x10.5" BFG AT's on Soft 8 wheels according to my bathroom scale.
Lighter wheels mean less stress on the steering/axle guts, less stress on your brakes, better ability to follow bumps via decreasing unsprung mass, and your stock tire carrier will like it better.
The strength debate either way is a bit of a moot point. When was the last time you broke a wheel - either steel or aluminum? If you're doing stuff that's going to break wheels you probably need beadlocks.
Well worth a little more money for aluminum, if you ask me.
hustler905 is offline
New wheels, Steel vs. Alloy bottlerocket91 TJ Wrangler Technical Forum 8 12-25-2010 09:49 PM
Wheels for offroad use, Steel or Alloy Rubydak JK Wrangler Technical Forum 39 04-10-2010 12:01 AM
Difference between steel and alloy wheels? mpo JK Wrangler Technical Forum 14 12-20-2008 10:40 AM
Wheels: Steel vs Alloy Evil_Trolloc Wrangler General Discussion 10 12-11-2008 06:56 AM
Difference Between Steel and Alloy Wheels? Avor TJ Wrangler Technical Forum 12 02-12-2004 10:26 AM
