State by State Vehicle Equipment Laws
#91 | |
Maryland
For people that don't feel like digging; in addition to the drivers side mirror, your bumpers have to be below 28" front and rear.
'The early bird may get the worm, but the second mouse gets the cheese.' |
#92 |
NY has no fender flare law???
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know). RED JEEP CLUB MEMBER #442 |
#93 |
I noticed someone posted a general link to the Transportation site for Saskatchewan, here is a direct link to the "Vehicle Equipment Regulations" document.
http://www.qp.gov.sk.ca/documents/English/Regulations/Regulations/V2-1R10.pdf |
#94 |
what is the fender law /tire coverage for ohio
Yeah, I think we're screwed. There are not nearly enough of us and time is running out fast. One day we will tell our grandchildren what it was like to have once been free. They'll likely think us demented. |
#95 |
Have you tried to Search........
#96 |
Need driver and passenger mirrors in Hawaii
Just talked to HPD...you need both driver and passenger mirrors if you take off the doors. Mahalo Hawaii....
#97 |
[*] West Virginia....WV Code Chapter 17C. Traffic Regulations and Laws of the Road
Equipment portions start with WVC 17 C- 15 - 1, scroll down in the side bar. Make special note of §17C-15-48 D F M Is now http://www.legis.state.wv.us/WVCODE/Code.cfm?chap=17c&art=15§ion=WVC%2017%20C-%2015%20%20-%20%20%201%20%20.htm#WVC%2017%20C-%2015%20%20-%20%20%201%20%20.htm
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
#98 |
I have been working on trying to get the Alaska codes and regs. Had a city officer look over my Jeep and without the covers on the lights, the wheels exposed beyond the fender flares, the lift, and the large stinger on the front, he said there was no problems with it. He is supposed to be getting me the latest book of code standards. If I don't get it from him, I will roll over to State Trooper barracks and see if I can get one from them. The Alaska DMV web site is absolutely horrid to find this information.
The only one that I have been able to confirm as a code at this date is: 13 AAC 04.005. Disconnection or Alteration of Equipment (a) For a vehicle intended to be operated on a public roadway, no person may disconnect or alter, except as is necessary in the repair or replacement of parts, equipment required by this chapter, unless the equipment is by nature designed and intended for disconnection or alteration; (b) No person may operate a motor vehicle upon a public roadway which violates the following limitations or prohibitions: (1) a motor vehicle may not be modified or altered from the original design so that any portion of the vehicle, other than the wheels, has less clearance from the surface of a level roadway than the clearance between the roadway and the lower most portion of any rim of any wheel in contact with the roadway; (2) a motor vehicle may not be modified to position the lowest portion of the body floor more than three inches above the top of the frame, or to result in a maximum frame height or body floor height greater than 24 inches for a vehicle of up to 4,500 pounds GVWR, 26 inches for 4,501 - 7,500 pounds GVWR, or 28 inches for 7,501 - 10,000 pounds GVWR. (c) No motor vehicle may be operated on a public roadway that has been modified, altered, manufactured, or is carrying a payload in a manner which adversely affects the steering, braking, or stability of the vehicle. (d) A vehicle operated on a public roadway that exceeds the minimum or maximum specifications of subsection (b) must be in compliance with this section by 3/31/93. (e) For purpose of this section (1) "frame" means the manufacturer's main longitudinal structural members of the chassis of the vehicle, or, for vehicles with unitized body construction, the lowest main longitudinal structural members of the body of the vehicle; (2) "frame height" means the vertical distance between the ground and the lowest point of the frame midway between the front axle and the second axle on the vehicle; (3) "GVWR" means the gross vehicle weight rating as defined in AS 28.40.100 (a)(9); (4) "payload" means anything added to a vehicle that increases its unladen weight. Still working on these and will get more when I find good dated material(s): Inspection of Vehicles 13 AAC 04.006 Emissions Requirements AS 45.45.400 License Plates Display of 28.10.171 Brakes Vehicles 13 AAC 04.205 Horn 13 AAC 04.210 Mirrors 13 AAC 04.220 Safety Belts 13 AAC 04.270 Tires 13 AAC 04.230 Unsafe Vehicles 13 AAC 04.225 Headlights Vehicles 13 AAC 04.020 Illumination 13 AAC 04.010 Miscellaneous Lighting Requirements 13 AAC 04.040 Parking Lights 13 AAC 04.070 Stop Lights Vehicles 13 AAC 04.035 Taillights Vehicles 13 AAC 04.025 I hope to find the location on the web but searches are not pulling up as much info as I would like.
2000 TJ, 1998 Grand Cherokee ZJ, 1983 CJ8 Scrambler (DJ Alaskan Postal Jeep) (FOR SALE!) www.militaryjeepers.com University of Louisville |
#99 |
Just a quick note for AZ, lift specifications are under article #18 now not #16
#100 |
JEEP THING
maryland?
how about some maryland info? i know theres a bunch of marylanders on here
Associates Degree in automotive technology Toyota Expert Chassis Technician ASE: A1(engine repair) A3(manual drive train and axles) A4(suspension and steering) A5(brakes) A6(electrical/electronic systems) OIIIIO |
#101 |
WV Code link is broken...correct links are:
http://www.legis.state.wv.us/WVCODE/Code.cfm?chap=17c&art=15§ion=WVC%2017%20C-%2015%20%20-%20%20%201%20%20.htm#WVC%2017%20C-%2015%20%20-%20%20%201%20%20.htm or a printable not as easily navigated site: http://www.legis.state.wv.us/WVCODE/ChapterEntire.cfm?chap=17c&art=15
#102 | |
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#103 |
Texas Statute 547.612 specific to tires:
TRANSPORTATION CODE** CHAPTER 547. VEHICLE EQUIPMENT |
#104 |
Does anybody know the bumper height in Fla.
#105 |
Jeep-aholic
Here is what I could find for Kansas:
Kansas Statues Go to Chapter 8 (Automobiles and Other Vehicles) and then choose Article 15 (Equipment of Vehicles)
1998 XJ - 3" RC Lift, new seat covers! Last edited by XJ-Wing; 08-21-2010 at 03:02 AM.. |
| Tags |
| bumper laws, code, law, legal, lift height law, lift laws, state law, statute, tire coverage, vehicel equipment laws, vehicle code |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
