Speedometer with 33's - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Speedometer with 33's
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 07-11-2013, 03:53 PM   #1
ToplessAllDay
I just put 33's on my 03 TJ 6 cyl auto. I have stock gears; I believe they are 3.73. I was running 35"s but wanted a little more power a semi better gas mileage. Here is my mathematics.
Lets say I was doing 20 mph, I would take the 2 and multiply by 2, add what it equals in place of the 0. (24 mph) 30 mph is 36, 40 is 48, 50 is 60, 60 is 72. so on. Is there a mathematical equation for 33's that anyone knows of?
ToplessAllDay is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 05:48 PM   #2
rchase559
It's just a percentage. 16.7 percent to be more specific.
If I'm understanding your post correctly, your speedometer is reading the initial speeds while you are actually traveling the seconds speed listed in each pair. This means that your speedometer is reading 16.7 percent slower than you are traveling.
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 07-11-2013, 06:48 PM   #3
krawler510
20 x 1.2 = 24
30 x 1.2 = 36
Etc...
I'm not sure what you're asking?
Stock tire diameter / new tire diameter = percentage of difference
Ex: 28/33= 0.848 so 15%
33/35= 0.94 so 6%
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline   Reply With Quote Quick reply to this message
