Spare tire - JeepForum.com
post #1 of 6 Old 04-14-2014, 10:00 AM Thread Starter
sgravess
Spare tire
Question, just bought my 02 TJ in February. Just recently found out that the PO installed 31x10.5x15s while leaving the spare the original 30x9.5x15. Is it ok to run this spare if I have a flat or will using the spare with that size which is different than the others damage something in the drive train. I don't mean using the spare to rotate in or anything, just using in an emergency in case of a flat to get me somewhere to repair the flat. Or should I replace the spare with one of matching size to the other four.
Thanks in advance
sgravess is offline
post #2 of 6 Old 04-14-2014, 11:03 AM
biffgnar
biffgnar's Avatar
If you run it on an open differential axle (no locker and no limited slip) it will be OK.
biffgnar is offline
post #3 of 6 Old 04-14-2014, 11:16 AM Thread Starter
sgravess
Great, thanks for the reply.
sgravess is offline
post #4 of 6 Old 04-15-2014, 09:28 AM
WXman
I'd just add that I wouldn't do this for a long time. It will be OK, but those spider gears are going to be getting a major workout and long term driving like this will likely cause problems. I'd just do it to get back home.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #5 of 6 Old 04-15-2014, 05:39 PM
2jhanna
Just like going around a very very large circle many times.
Sgravess, I was in the exact same boat, I kept an eye on craigslist and found a 31" used tire for $20, found a local shop to mount and balance for another $5.
Then sold my 30" the same way.
jhanna
denton county, tx
2jhanna is offline
post #6 of 6 Old 04-15-2014, 05:44 PM
2jhanna
Don't know what part of Minn you are from but this is just an example. Just keep a look out and you will find a deal.
Minneapolis
http://minneapolis.craigslist.org/hn...393781956.html
jhanna
denton county, tx
2jhanna is offline
