Spacers ? - JeepForum.com
post #1 of 9 Old 03-13-2008, 11:02 AM Thread Starter
jrs948
Spacers ?
I need to know what kind of spacers I need. I bought a 98 TJ at an estate sale and it has 31"s on the stock Gambler Rims. What kind of spacers should I buy to keep the tires from rubbing inside the wheel well? Thanks.
jrs948 is offline
post #2 of 9 Old 03-13-2008, 12:41 PM
Crashnburn80
Crashnburn80's Avatar
You need 5x4.5 1.25" spacers, I'd strongly recommend spidertrax and not an ebay special as this is a part you do not want to fail.
W/ Free shipping:
http://www.northridge4x4.com/proddet...SPIDER-WHS-002
Although you should be able to run 31x10.5" tires on your wheels stock without any serious rubbing issues. You may just need to adjust the steering stops.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 9 Old 03-13-2008, 01:47 PM Thread Starter
jrs948
Thanks for the help. Ya, it's not too bad, except when I'm pulling into parking spots and stuff. I prob could live with it, but I always enjoyed the tight turning radius of the jeep.
jrs948 is offline
post #4 of 9 Old 03-13-2008, 01:54 PM Thread Starter
jrs948
Got another question for you. I'm assuming I need these for all the wheels? The package comes in two's, that's why I'm asking. Also, is this a waste of $ if I'm gonna lift the jeep 2" or so?
jrs948 is offline
post #5 of 9 Old 03-13-2008, 02:54 PM
otisdog
2008 WK
Yea you need them front and rear. If it's just rubbing when you turn hard:
http://www.stu-offroad.com/steering/...teerstop-1.htm
Jim
08 Grand Cherokee Overland
otisdog is offline
post #6 of 9 Old 03-13-2008, 05:43 PM
Crashnburn80
Jim
^ Thats the steering stop adjustment mentioned earlier, you may try that first for 31s, most say it doesnt make a noticable difference in turning radius.
Yes you need them for all 4, so you need 2 sets of 2. They are not a waste for improvements down the road, lifting your Jeep wont stop the rubbing durring a turn and if you run larger tires you will NEED spacers or new wheels. Its also nice to have a little wider stance once you lift for better stability.
| 1.25" BL |
and much more...
post #7 of 9 Old 03-13-2008, 06:43 PM Thread Starter
jrs948
thanks again.
jrs948 is offline
post #8 of 9 Old 03-13-2008, 07:17 PM
CNY
Learn to live with it. When it rubs, it's at low speed and you're not doing much damage. If you ever REALLY need that extra turning radius, it's OK to put up with the rub for a second. Don't bother with the steering stop washer.
As for spacers, Spidertrax are overrated and overpriced.
http://www.jeepforum.com/forum/showt...76#post1880076
http://www.jeepforum.com/forum/showp...6&postcount=11
(Oh, and as for my opinion, I went with spacers)
CNY is offline
post #9 of 9 Old 03-13-2008, 08:44 PM
HoustonTJ
T-6 Billet seems to be working just fine...
I got a set of 4 spacers (T-6 Billet aluminum) for ~$100 off of ebay, and they work just fine. Just make sure you are getting Good metal and they are milled not cast.
HoustonTJ is offline
Spacers or BL? Narwhal Tires & Wheels 4 08-23-2008 11:57 AM
Would I need spacers? Longspoon Tires & Wheels 5 07-13-2008 11:04 AM
Rim Spacers? n00bie Tires & Wheels 3 12-01-2006 06:48 PM
OME + .75 spacers Brudos21 Tires & Wheels 3 05-11-2006 04:41 PM
why cant you just put 3'' spacers on a TJ jrodum Tires & Wheels 17 07-07-2005 01:31 PM
