Spacer lift vs Suspension lift - JeepForum.com
post #1 of 3 Old 10-31-2001, 05:56 AM Thread Starter
Jefff
Hoping to get some good feedback here...
I am looking to get a 2" lift put on my TJ, and I am still deciding on whether to go for a spacer lift or a suspension lift. I understand that a suspension lift is far better, but it will cost me about 3-4 times the cost (got a cheap spacer kit 2nd hand).
My question is this; How much better is an OME suspension lift than a Teraflex spacer lift?
Thanks
p.s I'm not looking to go higher than 2", so upgradability isnt a concern.
Jefff is offline
post #2 of 3 Old 10-31-2001, 11:56 AM
evilpsych
evilpsych's Avatar
well..
susp. lift runs you into all kinds of problems.. drivetrain angles.. SYE kits.. not to mention new diff gears depending on the tire size..
same goes for body lift.. bout the only prob i can think of with body lift is the tires rubbing when turned all the way..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #3 of 3 Old 11-02-2001, 03:48 PM
igofshn
Locked @ both ends
igofshn's Avatar
If you are not looking at going any higher than 2" then a spacer lift is what you want. daystar has 1.75" spacers and a complete set will run around $80.00 and take less than 2 hours to install with basic tools. Shocks are seperate but are not required, but I would eventually get new shocks. With this lift you can fit 32's.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
Can I clear 32x11.5x15s with only a 2.5 suspension lift (no body lift) on my 2006 TJ? ddonjon General Jeep & Off-Road Equipment 3 04-21-2009 10:49 AM
Spacer Lift Or Spring Lift happycamper Tires & Wheels 6 07-16-2006 12:27 AM
Skyjacker 2" spacer lift vs Rubicon Express 2" spacer lift silverjeepin Tires & Wheels 8 11-23-2004 10:59 PM
Coil Spacer Lift vs. Body Lift JeepZen Tires & Wheels 4 06-28-2003 08:38 PM
Spacer Lift or Body Lift?? Help Guys!! TJ LUVER Tires & Wheels 2 03-04-2002 09:45 PM
