Spacer Lift Or Spring Lift - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Spacer Lift Or Spring Lift
Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!
Unread 07-10-2006, 11:14 PM   #1
happycamper
1986 XJ Cherokee
I Just Bought My Tj A Few Weeks Ago So Yes I'm A Noob I Just Figured Out My Jeep Has A Spring Spacer Lift R These Junk Should I Get A Spring Lift What R The Pros And Cons Of Each If There Is Any I'm Not Doing Any Xtreme 4x Pretty Much Just Trails For Now At Least . Thanks For Any Help In Advance
happycamper is offline   Reply With Quote
Unread 07-11-2006, 05:58 AM   #2
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I think spring spacer lifts are fine. They are good for n00bs who want to get into lifted Jeeps. If you stay there for awhile you may find in the future you want to go to a bigger spring lift. Spacer lifts are safe if that is kinda what you are asking.
I look at spacer lifts as the gateway dug of lifts...
2013 FR-S
BlaineWasHere is offline   Reply With Quote
Unread 07-11-2006, 09:23 AM   #3
markc522
springs.
so when you want to go bigger you can add spacers.
i wish i did it right from the beginning. now i have a frankenlift.
2003 wrangler x
somewhere around a 4" frakenlift -
33" claws - black soft 8's - dt8000's - disco's
yellow jeep club member #874
JEEP: 1 2 3 4 5 6 7 8 9 10
markc522 is offline   Reply With Quote
Unread 07-14-2006, 10:12 AM   #4
roxymom
Ooh, I need help!
I just bought a 99 Sahara and they said it had a lift but they removed it, but I think it might still have a lift. How can I figure that out?
Thanks!
roxymom is offline   Reply With Quote
Unread 07-15-2006, 03:22 AM   #5
Rocky5
Originally Posted by markc522
springs.
I agree! I also used spacers to level out my lift...in my opinion, spacers are a good way of adding to/correcting an existing lift. Besides, springs are a better investment and only cost a little more.
2006 [COLOR=Yellow]Solar YELLOW[/COLOR] UNLIMITED-6-Speed
-Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines
-Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar.
Rocky5 is offline   Reply With Quote
Unread 07-15-2006, 03:25 AM   #6
BlaineWasHere
BecauseRacecar
Thanks!
Mesure from the ****er of the hub to the bottom of the fender and compare to stock.
2013 FR-S
Unread 07-16-2006, 12:27 AM   #7
nicolas-eric
i installed 2" spacers a few weeks ago. it looks like a real 2" spring lift. but off the road without disconnects it does not work better than without the spacers. the tires loose contact to the ground as fast as before.
i will replace the 2" spacers and the original springs with some 2.5" springs in a few days. the 2.5" springs from skyjacker are very good (on- and off-road) in a friends TJ and i think i will buy them.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
