SOA Lift Equation - JeepForum.com
post #1 of 5 Old 05-31-2001, 01:23 AM Thread Starter
Dustin Maschino
SOA Lift Equation
I've been doing a lot of thinking about an SOA conversion and have come up with an "equation" but need someone else to tell me if im forgetting something....
here's the equation...
2x(Spring Height+1/2Spring Thickness+Axle Radius+ Spring Perch Height)=Overall Lift
if im doing something wrong here, please tell me......
Dustin Maschino is offline
post #2 of 5 Old 05-31-2001, 10:03 PM
osburn
osburn's Avatar
From your current height, assuming you use the exact same springs, your total lift will equal 2 x the thickness of the perches (assuming you use the same kind) plus the diameter of the axle tubes plus the thickness of the spring pack.
Matt Osburn
Score 1032
osburn is offline
post #3 of 5 Old 06-01-2001, 12:24 AM Thread Starter
Dustin Maschino
well ive done more work with this equation thing and when lifting you should measure from the center point of the axle which would be the axles radius. while thinking about this today i found that i figured everything wrong....so i found another one
2(axle radius+˝spring thickness+perch height) = overall lift
if anyone has done an SOA calculate this up and tell me if i have it right now...
post #4 of 5 Old 06-02-2001, 09:15 PM
osburn
osburn's Avatar
I think you're making this much too complicated for yourself. If you must have a formula it is:
Axle diameter + spring pack thickness + old perch thickness + new perch thickness = total lift
Matt Osburn
Score 1032
osburn is offline
post #5 of 5 Old 06-10-2001, 12:09 PM
Cody_91YJ
Ya, that looks a bit simpler
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
tire pressure equation Marn Tires & Wheels 26 08-01-2013 03:30 AM
Can I clear 32x11.5x15s with only a 2.5 suspension lift (no body lift) on my 2006 TJ? ddonjon General Jeep & Off-Road Equipment 3 04-21-2009 10:49 AM
Crawl Ratio Equation? Duble-it Engines & Drivetrain 6 07-03-2008 11:14 PM
Whats the diff between Body Lift and Suspension Lift? loudog3114 Tires & Wheels 7 02-01-2005 02:27 PM
Will a Lift Void my warrany - Lift Suggestions needed johnobennett Tires & Wheels 10 10-23-2003 12:04 AM
