Sipe pattern question - JeepForum.com
post #1 of 10 Old 11-26-2013, 03:01 AM Thread Starter
TurboGoKart
Maxxis Creepy crawlers. I'm trying to figure out what a good pattern to sipe these inner tread blocks is. I was thinking a "Z" pattern within the tread block, with out the straight lines of the Z touching. I don't know if that will be enough, or if I should just have Discount Tire do whatever pattern they normally do. Any suggestions?
Fully Cloak'd!! :)
35" KM2's
Bumpers, winch
TurboGoKart is offline
post #2 of 10 Old 11-26-2013, 12:04 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The tire siping that Discount Tire does runs perpendicular to the sidewall.
And the sipes are about 1/4" apart.
They can adjust the depth of the sipes and also how far the sipes extend to the outer tread blocks.
If you are cutting Zs within a tread block, that is more often referred to as tire grooving.
Sorry, I do not have any input on the siping/grooving pattern you should use.
Wheelin98TJ is offline
post #3 of 10 Old 11-26-2013, 12:12 PM Thread Starter
TurboGoKart
Thanks! I wasn't too sure about their process so that helps. I was thinking I may want some sipes running the circumference of the tire for lateral stability. And I just meant the Z pattern for the siping, not actual grooving.
Fully Cloak'd!! :)
35" KM2's
Bumpers, winch
post #4 of 10 Old 11-27-2013, 02:02 PM
swirve
I doubt they will sipe worn tires
swirve is offline
post #5 of 10 Old 11-27-2013, 02:49 PM
Wheelin98TJ
JEEP FREAK
Discount Tire will sipe them as long as you have 1/4" of tread.
post #6 of 10 Old 11-27-2013, 02:52 PM
jski701
jski701's Avatar
Any idea what they charge ?
I aint saying its right, but I understand......Chris Rock
jski701 is offline
post #7 of 10 Old 11-27-2013, 02:56 PM
Wheelin98TJ
JEEP FREAK
$10/tire last time I had it done at Discount Tire.
post #8 of 10 Old 11-27-2013, 04:20 PM Thread Starter
TurboGoKart
Yup, that's still the standard. How much can their machines 'customize' the sipes, or are they only one pattern?
Fully Cloak'd!! :)
35" KM2's
Bumpers, winch
post #9 of 10 Old 11-28-2013, 07:26 AM
Wheelin98TJ
JEEP FREAK
Just one pattern. Straight sipes that run perpendicular to the sidewall.
post #10 of 10 Old 11-28-2013, 07:49 AM
jski701
jski701's Avatar
The guys on my other forum, use a box cutter, and make cuts every 1/4" to 1/2"
I'd never heard of it, and bought tires, but probably could have gotten another year or 2 out that set. They would slide at the slightest acceleration, and on highway ramps too and were awful in rain..
jski701 is offline
