-   Tires & Wheels (http://www.jeepforum.com/forum/f15/)
-   -   Sipe pattern question (http://www.jeepforum.com/forum/f15/sipe-pattern-question-1829506/)
TurboGoKart 11-26-2013 03:01 AM
Maxxis Creepy crawlers. I'm trying to figure out what a good pattern to sipe these inner tread blocks is. I was thinking a "Z" pattern within the tread block, with out the straight lines of the Z touching. I don't know if that will be enough, or if I should just have Discount Tire do whatever pattern they normally do. Any suggestions?
http://i1317.photobucket.com/albums/...ps033850c7.jpg
Wheelin98TJ 11-26-2013 12:04 PM
The tire siping that Discount Tire does runs perpendicular to the sidewall.
And the sipes are about 1/4" apart.
They can adjust the depth of the sipes and also how far the sipes extend to the outer tread blocks.
If you are cutting Zs within a tread block, that is more often referred to as tire grooving.
Sorry, I do not have any input on the siping/grooving pattern you should use.
TurboGoKart 11-26-2013 12:12 PM
Thanks! I wasn't too sure about their process so that helps. I was thinking I may want some sipes running the circumference of the tire for lateral stability. And I just meant the Z pattern for the siping, not actual grooving.
swirve 11-27-2013 02:02 PM
I doubt they will sipe worn tires
Wheelin98TJ 11-27-2013 02:49 PM
Discount Tire will sipe them as long as you have 1/4" of tread.
jski701 11-27-2013 02:52 PM
28 Attachment(s)
Any idea what they charge ?
Wheelin98TJ 11-27-2013 02:56 PM
$10/tire last time I had it done at Discount Tire.
TurboGoKart 11-27-2013 04:20 PM
Yup, that's still the standard. How much can their machines 'customize' the sipes, or are they only one pattern?
Wheelin98TJ 11-28-2013 07:26 AM
Just one pattern. Straight sipes that run perpendicular to the sidewall.
jski701 11-28-2013 07:49 AM
28 Attachment(s)
The guys on my other forum, use a box cutter, and make cuts every 1/4" to 1/2"
I'd never heard of it, and bought tires, but probably could have gotten another year or 2 out that set. They would slide at the slightest acceleration, and on highway ramps too and were awful in rain..
The time now is 08:50 AM.
