shaky steering wheel clunking noise help! - JeepForum.com
post #1 of 10 Old 01-09-2014, 05:29 PM Thread Starter
Kristina01
I have a 2001 Jeep Cherokee Sport. I just had the tires replaced and found out that I have broken sway bar link on the passenger side. I also have an issue I can't place. Recently there has been a knocking sound when i turn either left or right. Now no matter what way I turn even in reverse my steering wheel shimmies and looks like its trying to drive itself and the wheels make that knocking sound even worse. Please help!
Kristina01 is offline
post #2 of 10 Old 01-09-2014, 05:44 PM
kensnelling
Well, since you didn't say, have you checked/retorqued your wheels? These guys at the tire stores I've had them strip studs and nuts nefore using their impacts installing rims.
Ken
kensnelling is offline
post #3 of 10 Old 01-09-2014, 06:35 PM Thread Starter
Kristina01
the clunking started before i had my tires changed. today i went over a speed bump and yes i went slow, turned onto a road way and my front driver side wheel popped very loudly. im getting ready to call my mechanic to look at it but if i can find a reason before i call them i can save myself some money
post #4 of 10 Old 01-10-2014, 12:28 PM
Red Rubicon
Could be an axle u-joint.
Red Rubicon is offline
post #5 of 10 Old 01-11-2014, 11:33 AM
kensnelling
Ok, from your first post I thought the problem started after you had the tires replaced. Several suspects to look at. Trackbar, control arm bushings, and/or ball joints can cause the symptoms you describe.
Also, do you have 4WD, and if so, is it Command Trac or Select Trac? If it's Command Trac and you have it in 4hi or 4lo, or Select Track and have it in 4 part time it can cause those problems too on hard surfaces.
Ken
post #6 of 10 Old 01-19-2014, 07:42 PM
04KJlimited
2004 KJ Liberty
Check the trac bar. Sounds like death wobble
04KJlimited is offline
post #7 of 10 Old 01-19-2014, 07:48 PM
supersport126
I would get it to a front end shop and have them check it out. Sounds like ball joints, it also sounds dangerous
supersport126 is offline
post #8 of 10 Old 01-19-2014, 08:00 PM
apaTJ
I'm guessing ball joints or wheel bearings. A broken u joint won't really cause wobble in the wheel if the bearing is good.
apaTJ is offline
post #9 of 10 Old 01-19-2014, 08:05 PM
apaTJ
Sorry I meant to finish that. You can do a little troubleshooting if you have some jack stands and a jack. Lift the front end off the ground at the axle. To check the wheel bearings, take the tire at 12 and 6 o'clock and pull to check for any play. Do the same at 3 and 9. If there is any play the bearing is bad. A bad wheel bearing seems to go slowly and get progressively worse. If that's not the issue, have someone turn the wheel back and forth while you look for play in any of the steering joints and ball joints. You should be able to tell if any of them are bad. Hope this helps
apaTJ is offline
post #10 of 10 Old 01-26-2014, 12:03 PM
jimmy_jimenez
Better check your steering linkage to have a safer ride.
I am an immigrant from Mexico and I love my '95 YJ . English not so good but I like to write here.
jimmy_jimenez is offline
