Shackle and Suspension Lifts - JeepForum.com
post #1 of 2 Old 06-22-2001, 10:10 AM Thread Starter
GroundUpCJ7
I'm going to add a lift to my 1980 CJ7. I was wondering if it would be better to use a straight out of the box suspension lift, or combine a 2.5" suspension lift with a 1 - 1.5" shackle lift. I'm thinking of finishing the lift out at 3.5 - 4.0", but the final height is not as import as handling and responsiveness. Also, any suggestions on whose putting out the best lifts? Oh yeah, I have reverse shackle mounts on the frame. I'm going to go with with 31-33" tires, will probably drop the transfer case, and installed a dropped pitman. This vehicle is not going to be a daily driver, but will see a lot of road use.
Thanks.
It's not so much a labor of love as it is shear determination.
GroundUpCJ7 is offline
post #2 of 2 Old 06-25-2001, 11:38 PM
osburn
osburn's Avatar
If handling is important, then don't EVEN mess with shackle lifts. You'd be better off buying a 4" kit than the mix you're suggesting. I'd only suggest the shackles if you can't afford the lift kit.
Matt Osburn
Score 1032
osburn is offline
BDS Suspension Lifts - Where to Buy? CityJeep Tires & Wheels 7 07-04-2005 01:01 AM
Shackle Lifts UltimatE Tires & Wheels 2 11-10-2004 04:32 PM
Shackle lifts!? Crnf2 Tires & Wheels 2 10-10-2004 09:53 AM
shackle lifts yea or nay?????? vetteman9368 Tires & Wheels 12 01-22-2004 07:48 PM
Shackle lifts mikeythefireman Tires & Wheels 5 03-02-2002 10:17 AM
