Setting camber on front wheels? - JeepForum.com
post #1 of 5 Old 09-10-2008, 06:48 AM Thread Starter
possumwalk
Can the camber be adjusted on the front wheels on our Jeeps(YJ). If so, how? The left wheel on mine is tilted in at the top (negative camber). I see no way to correct. TIA.
possumwalk is offline
post #2 of 5 Old 09-10-2008, 07:28 AM
ajmorell
ajmorell's Avatar
No, you need offset balljoints to adjust the camber.
ajmorell is offline
post #3 of 5 Old 09-10-2008, 09:40 AM Thread Starter
possumwalk
Thanks,ajmorell. I don't mean to sound like a dumba$$ on this,but I am. Could you please elaborate on this a little bit. Do I need to replace with stock ball joints? Does some one make "off set ball joints" in different angles? I like to,and in most cases am able,to do my own work. Would I be better off taking to a front end shop(God forbid) and let them do it? Thanks.
post #4 of 5 Old 09-10-2008, 12:11 PM
mdm
Farm Wheeler
Originally Posted by possumwalk View Post
...The left wheel on mine is tilted in at the top (negative camber)...
Your Jeep is supposed to have a negative camber. Both sides should be the same. If your right and left wheels have a different amount of camber that you can see, you probably have a problem. I would start by looking at the right side to see why there is no negative camber. You might take it to a shop and have the camber measured so you really know what you have going on. Things like this can be hard to eyeball.
mdm is offline
post #5 of 5 Old 09-11-2008, 06:39 AM Thread Starter
possumwalk
Thanks, mdm. From what I gather camber is not adjustable. The Chilton shop manual calls for 0 degrees on camber. I just got this YJ with 114,000 miles on it.( First Jeep) It has been treated like a Jeep. Maybe ball joints need replacing. As this seems like the way camber is affected. Has clearly visiable negative camber on left wheel and more tire wear on inside part of tire. With new hub assembly. Thanks for help. A work in progress.
Nothing like a JEEP!
camber adjustment on solid rear axle Ja$onMagnum Tires & Wheels 2 07-01-2009 02:34 PM
Setting SOA front Perch/Castor Angle JeeperDon Fabrication Shop 3 12-03-2006 12:37 PM
setting in the waggy front and establishing positive castor Blthomas Engines & Drivetrain 3 05-08-2006 10:48 AM
Straightening Front Wheels Chest_Rockwell Tires & Wheels 2 12-31-2005 12:51 PM
camber LOCKED UP General Jeep & Off-Road Equipment 4 08-25-2003 09:14 AM
