running directional tires backwards ?? - JeepForum.com
post #1 of 21 Old 07-16-2007, 11:27 PM Thread Starter
raider_man007
I've heard if you have directional tires and run them backwards you get alot more traction. I would like to try this but I don't really want to load up the floor jack and rotate my tires at the beginning of the trail. My question is ....is it ok to drive with my tires backwards on the pavment. Does anyone run there tires like this all the time. I would think the tires would wear funny and would cause vibes.
1999 black wrangler sport 4.0 auto
d30 up front 8.8 w/ detroit in rear
4.10 r&p disc's all around
tom woods cv driveshaft w/ sye
4 inch's of suspension lift
35x13.50 baja claws
raider_man007 is offline
post #2 of 21 Old 07-16-2007, 11:33 PM
BYuen
BYuen's Avatar
No idea... However I figure they would design the tire tread in a way so that it would have the most traction rotating in the proper direction (forward)? You could test it out and let us know. Just watch the tread wear. You won't experience tire failure or anything if that's what you're worried about.
BYuen is online now
post #3 of 21 Old 07-16-2007, 11:34 PM
Unscathed
I don't know off hand, but it sure would suck if you had to back up and had no traction.
I know when I was running parrelli tires on my Blazer, they were direction tires.. and the dumbarse tire shop put them on backwards and I was sliding all over cause it messed with my traction.. SPECIALLY when it rained.
Not sure if you are going to get alot of posts on this question... companies make directional tires for one reason.. to get better tracktion in one direction.. lol
Best Axles and service you will find.
The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost!
Unscathed is offline
post #4 of 21 Old 07-16-2007, 11:38 PM
tcox
yea they always say its a "good idea" or something like that on extreme 4x4. but who knows for sure. its seams like a good idea for the trail, but not so much for pavment
stuff
tcox is offline
post #5 of 21 Old 07-17-2007, 12:13 AM
spittindurt
spittindurt's Avatar
I run my boggers backwards every other rotation, but just to get even wear out of them. Normal rotation is rears strait forward and fronts X to the rear (rear wheel drive) but with my boggers I just run them all forwards and then run them all backwards. True looks goofy but they do wear a lot better this way.
As for the highway, reverse they are LOUDER if thats even possable (boggers...) decrease highway cruseing power/mpg and they dont clean as good in the mud but thats because they were designed to be run forwards.
A lot of people will run the rears faceing forwards and the fronts backwards so they have equal traction in reverse.
They also wont clear water out of the tread as well because the lugs will be forcing the water twords the center of the tire rather than out....
2003 X With a little of this and a little of that.....
Check it out at
Real men run Super Swampers on their JEEP
Chrome won't getcha home!
spittindurt is offline
post #6 of 21 Old 07-17-2007, 12:33 AM
Medicjaycook
Running backwards
The whole reason for running them backwards from what I have read is you run your Fronts backward and rears in the tires normal direction. this gives you traction if you have to reverse. other then that I am not sure.
Medicjaycook is offline
post #7 of 21 Old 07-17-2007, 01:20 AM
dirtbagofva
2010 JK Wrangler
the direction of the tread affect braking too. on my R/C car i reversed the tires and got awsome traction forward...couldn't stop though. That little ba$tard sure could pop a wheely though.
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline
post #8 of 21 Old 07-17-2007, 01:57 AM
vtx531
As far as I know, directional tires only work well in the direction they were designed for. When you run them backwards, they pack mud INTO the tread instead of clearing. One time that I got stuck bad, a guy with tractor tires pulled me out. He said he had to pull me out with his rear towpoint because if he tried in reverse using the front then he would have no traction.
I have also heard the theory that directional tires are designed so that you have more traction in reverse so you can back out of a stuck situation. My personal experiences show this not to be true.
vtx531 is offline
post #9 of 21 Old 07-17-2007, 02:18 AM
dirtbagofva
2010 JK Wrangler
...the farmers i know prefer to pull things out in reverse...keeps the tractor from flipping
post #10 of 21 Old 07-17-2007, 02:20 AM
'B'wigstrailrig
Probably make gas mileage worse
'B'wigstrailrig is offline
post #11 of 21 Old 07-17-2007, 07:41 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
WHOA!!!!!!!
You could run them backwards OFF road becuase you don't reach highspeeds... HOWEVER you don't want them backwards if you drive this Jeep on the street!
2013 FR-S
BlaineWasHere is offline
post #12 of 21 Old 07-17-2007, 08:14 AM
frankiefire702
I run them backwards on my rig!
06 tj locked on 36's.
frankiefire702 is offline
post #13 of 21 Old 07-17-2007, 08:38 AM
Chris_
That's called tractor tipping.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #14 of 21 Old 07-17-2007, 08:42 AM
cookeab
Flatlander
cookeab's Avatar
My baja claws like being reversed in the mud.
cookeab is offline
post #15 of 21 Old 07-17-2007, 12:17 PM
Drednot
Ive had it help only while running in the sand dunes.
It would try to pack the sand under the tire and not sink in so far.
Drednot is offline
Directional Tires Backwards justanotherjpr Tires & Wheels 12 05-07-2009 05:51 PM
Directional tires... smcurry83 Tires & Wheels 3 12-13-2007 10:33 AM
Running Claws Backwards tennis203 Tires & Wheels 2 04-10-2007 10:47 AM
How is Kuhmo's directional mud or other directional tires. Fargo Tires & Wheels 0 10-17-2006 03:56 PM
Directional tires...what about the spare? Chris_ Tires & Wheels 5 10-04-2006 05:59 PM
