Rubicon original tires in the wet or snow
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Hi there,
My wife has a Rubi '06 with original tires...Jepp is home and I'm at the office so I appologise not to know what they are, but they were what came brand new with the jeep. Am I dreaming or are these tires almost dangerous in the wet and snow ? Must admitt I drivre mostly a 3/4 ton pick up so don't have much mileage on the jeep but it seems to me that these tires hydroplan like crazy...don't seem to have rain grooves on them...in the winter we simply park the jeep because it's unusable. I do realise that a short wheel base is slightly less stable but I do see lot's of folks out there in winter with their jeeps. I assume a skinnier winter design tire would be better but I'm trying to figure out if it will make such a big difference before I spend the $$$. Any opinion on the originals Rubi tires ?? Thanks in advance for the help.
#2 |
JEEP FREAK
They are 245/75/16 Goodyear MTRs and they consistently get bad reviews from Rubi owners.
The other MTRs that you buy in the aftermarket work excellent, but the original equipment MTRs that come on Rubicons are for some reason pretty much opposite.
98 TJ |
#3 |
While their not the best in the rain, I don't have a hydroplane problem at all. I don't even remember every hydroplaning. They do tend to slide around a lot when going around corners and such.
#4 | |
Wow.... I'm from Barrie way. My TJ had little trouble on the hard-pack roads I travel on, even with the stock GSA's. Those must be really bad tires... anyway, my winter tires have improved my confidence 100% over the GSA's. Winter tires are your best insurance on winter roads. Some insurance companies offer rate reductions if you use them, too. ![]() |
#5 |
I have a set of 31x10.5 MT/Rs on my Jeep right now, which are about the same size as your stock Rubi tires. I can't say anything at all good about them.
They are insanely loud, and absolutely suck in the rain. I haven't had them wheeling, but I'm sure they do well off road. On the road, they are a terrible tire, and I can't wait to get rid of them. I wouldn't recommend these for a daily driver any more than I'd recommend Super Swampers. |
#6 |
JF is my second home.
I had MTRs on my Rubicon, and yes they suck in wet or ice, deep snow they work ok though. If you don't go in the mud much I would look at some AT tires, or if you want the aggressive look or go in the mud, but still good on ice and water a hybrid MT/AT would be good compromise. Good Year Duratracs are a hybrid and work great in most conditions except very deep swampy mud that only a good MT or swamper will work in. I bought Mickey Thompson MTXs at the time they don't make them anymore, but they were also some what of hybrid, but much more like an AT than an MT, but they had larger voids and still worked well in the mud.
Max 2003 Jeep Wrangler Rubicon 4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs. TJ Tech Boot Camp TJ Specs "Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track" |
#7 |
Mt/R's are terrible in mud imo. They clog & are just like a slick, even with easy riding in light mud. Overall, I will not be buying another set.
#8 |
When you post, be sure to clarify if you are talking about OEM MT/R's or aftermarket, because like Wheelin98TJ says, there is a huge difference.
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
#9 | |
No, not really. They both are exceptionally poor on wet or icy roads and far louder than they should be for a modern tire design. It's probably a good tire choice for folks in the SW who drive in rocks more than rain. The new 'kevlar' version may be different; I haven't had any seat time with those yet.
2002 TJ SE 2004 WJ Laredo 4.7 2006 LJ 2007 Rockwood Freedom 2280 "...in the GOP, enthusiasm is measured in Reagan units." |
#10 |
Actually it is a fact, completely different tread compound.
#11 |
#12 |
Doesn't matter; net effect is the same: wet pavement suckage.
What is the source of this "different compound" factoid?
#13 | |
Besides, the "suckage" is easily remedied by spending a couple hours with a razor siping the tires. All of this is fairly common knowledge.
#14 | |
I have in fact spent a few minutes siping mine with the ideal heated tire knife stored in my toolbox. It doesn't remedy the suckage. The older style MT/R is a lousy wet pavement tire. At least the four different sets I have experience with sure are - regardless of the added hand siping. I haven't had a crack at the new ones yet, so I can't say. I think in your context "fairly common knowledge" means, "I read it on the internet so it must be true." It's not a bad tire, it's just a bad tire for slippery conditions.
#15 |
BFG did the same thing with the Mud Terrains put on JK rubi's.
I do not disagree that the MT/R isn't a great wet/ice tire. However, it is no worse that some AT's and many MT's that I have experienced.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
