Rough Country Lift - JeepForum.com
post #1 of 15 Old 10-10-2001, 04:35 AM Thread Starter
bonehead99
bonehead99's Avatar
Rough Country Lift
Could someone tell me what all comes in the 3" rough country lift? How well does this lift ride? Will it start sagging quickly?
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #2 of 15 Old 10-10-2001, 07:39 AM
jobob
I ordered mine directly from Rough Country for $389. Came with springs, degree shims, spring bushings and sleeves, t-case lowering kit, trac-bar relocation brackets, brake line relocation brackets, u-bolts, bumpstop extentions(which I didn't use), shocks, dropped pitman arm, and nuts and bolts. Easy to install. Of course the ride is more stiff than stock, as with any lift, but it is not bad. It has settled just a little since June, but is still close to 3" over stock.
jobob
jobob is offline
post #3 of 15 Old 10-10-2001, 01:47 PM
OhYeah
I sent you an email!
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #4 of 15 Old 10-10-2001, 02:48 PM
rivertrout10
rivertrout10's Avatar
Dont know what your budget is - however - in my opinion the only way to go is the Rubicon Express lift kit system. It will cost you nearly 1k - but well worth it. It is a totally complete kit (shocks, transfer case lowering hardware, extended stainless steel brake lines, etc). I have had mine for around one year without a bit of sagging. If you are applying to a CJ you will be getting wider front springs which, I believe, help to eliminate front sagging. You should visit the Rubicon Express website as they have a schematic of what their kits come with. It came complete - and installed without problems. I have seen other lift kits that sag after about a year. Mine doesnt.
Jeep - its a job - not an adventure
rivertrout10 is offline
post #5 of 15 Old 10-11-2001, 03:58 AM Thread Starter
bonehead99
bonehead99's Avatar
With this lift will I need longer brake lines? Right now I'm on a very tight budget, so 1K is way to much. I am not adding a lift becuase I want one. I have a front spring that has snapped at the eye and a bent rear spring.
post #6 of 15 Old 10-11-2001, 09:18 AM
helter
Have you looked into getting springs from a junkyard?
Would you have to get all 4 to insure consistent wear?
92 YJ - 30x9.5 BFG
helter is offline
post #7 of 15 Old 10-11-2001, 10:15 AM Thread Starter
bonehead99
bonehead99's Avatar
A used spring may alter the height at each corner. I rather replace stuff on my Jeep with new parts. This is my first Jeep and I want to keep it for a longtime. I shouldn't say I don't want a lift. I purchased a body lift a few weeks ago but now I have a need for a real lift. If anyone is looking for a 3" body lift let me know. Still in the box.
Helter do you know any good trails here in Toledo? I heard that the Jeep dealer has a course setup, not sure if you can bring your own Jeep.
post #8 of 15 Old 10-11-2001, 10:17 AM
rivertrout10
You will need longer brake lines - however the kit comes with extended braided steel lines - so you would not be purchasing additional equipment. RE offers a 2.5 inch lift that is a few dollars less - not sure on the prices anymore, but their website offers good info.
http://www.rubiconexpress.com
Good luck.
RE
post #9 of 15 Old 10-20-2001, 09:55 PM
mark johnson
i bought a kit from rough country for only $225 itcame with front springs and a rear add a leaf
mark johnson is offline
post #10 of 15 Old 10-21-2001, 06:35 PM
AJ
With RC you will not need new brake lines, the kit includes extenders which work fairly well. The rides a little bouncy, but it's not too bad. Good job staying away from the body lift.
AJ is offline
post #11 of 15 Old 10-21-2001, 06:35 PM
AJ
AJ is offline
post #12 of 15 Old 10-21-2001, 06:36 PM
AJ
AJ is offline
post #13 of 15 Old 10-22-2001, 04:39 AM Thread Starter
bonehead99
bonehead99's Avatar
After TWO days of work I have my RC 3" lift installed. I still need to install pitman arm. We broke 2 pitman arm pulls trying to get it off. I had 2 sleeves froze to the bolt. I had to torch one bolt, so I replaced rear spring bolts with grade 8 bolts. Then 2 bolts in the skid plate where spinning in the frame, torched them off. The lift looks great!! If someone with a stock yj could measure the height on the frame between the front bumper and the grille. I know it made a huge difference!! My 31s look to small, now I need 33s. My rear driveshaft still seems like its binding. Could I lower the skidplate another 1/2"? My steering wheel is not centered anymore, is this due to not having pitman arm installed? Thanx for answering all my question.
post #14 of 15 Old 10-23-2001, 12:11 PM
OhYeah
Hey buddy,
what happened to the phone call. Oh well, sounds like it went well with only a few small issues (typical). I had the same problem with my pitman arm. I was so tired from messing with the lift and breaking pullers, banging with a BFH, I took it over to Midas and let them get it off. They will take it off for about $20. Your steering wheel will be straight once it goes on. I know what you mean about getting bigger tires. I need 33's as well. With my 31's I look like I am standing on stilts or something. Glad you like it. Peace,
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #15 of 15 Old 11-04-2001, 04:00 PM
CR Perry
I wouldn't lower the skidplate anymore. With the spacers I use the transmission will sometimes pop out of second gear. I'll be getting the slip yoke eliminator kit next year. Your steering wheel should be off to the right. When the axle gets further away from the steering box its the same as shortening the drag link. The guys at the alignment shop should be able to help you out.
95 Wrangler
Rubicon Express 4.5" Lift
CR Perry is offline
Know anything about 3.25 Rough Country lift? Sahara97TJ General Jeep & Off-Road Equipment 4 04-09-2009 05:38 AM
Rough Country Lift BGR500r Tires & Wheels 1 07-27-2007 12:27 AM
rough country lift kit Durbahn Tires & Wheels 3 06-18-2003 07:59 AM
rough country 4in TJ lift dharper Tires & Wheels 2 12-11-2002 01:57 PM
No more $350 for Rough Country Lift bonehead99 Tires & Wheels 0 10-16-2001 04:05 AM
