Quantcast Rough Country 2.5" Progressive lift - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Rough Country 2.5" Progressive lift
SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 08-16-2008, 03:26 AM   #16
jeep2008
i repeat what i said in another thread:with all the bb's around you can GET AWAY without anything else but this DOESN'T mean that they wouldn't be BETTER with transfer case drop kits,relocation brackets,adjustable track bars,adj lca etc IF you want to be sure that your jeep is 100% safe and functional!!
my build thread
04TJ (SOLD)
01TJ (BUILDING)
jeep2008 is offline   Reply With Quote
Old 08-16-2008, 04:50 PM   #17
shane_huskey
just a quick note to unlimited04. i dont know if you have thought about this, but as you take stuff off, you take weight off the jeep .. therefore the 100 lb bumper you added doesnt add 100 lbs to the jeep. it adds 100lbs minus the stock bumper weight. another thing, if you are wanting to get 2.5 inches of lift, and you feel that you eat more cheeseburgers then other guys, try buying a 3.5 inch lift, and let it droop an inch. obviously that isn't the ideal fix, but paying almost 800 bucks for a 2.5" lift from OME is a little rediculous in my book. now this isnt supposed to be a smart *** remark or anything, just throwing some ideas out that i would think of if i was in the same situation as you are.
'06 6cyl 6spd X - 2.5" Rough Country Progressive Springs, Rough Country Performance 2.2 Shocks and Steering Stabilizer, 1" PA BL, 1" JKS MML, 33x12.50 TrXus M/T's w/ Spidertrax 1.25" Spacers on 15x8 Ravines
JEEP is spelled wrong.. It should be spelled J-U-N-K
shane_huskey is offline   Reply With Quote
Old 08-16-2008, 06:24 PM   #18
hotwiredxj
Lift is installed, please look at the first post to see pics and see what I have to say about this lift and the install.
Jeep TJ - Rough Country 2.5" Progressive lift install Write-up:
http://www.jeepforum.com/forum/f15/rough-country-2-5-progressive-lift-593851/
hotwiredxj is offline   Reply With Quote
Old 08-16-2008, 07:02 PM   #19
lactrain
Am I missing something ... I dont see the pictures of the installation or the write up.
2005 Rubicon Impact Orange, AtoZ Rockers, Rough Country 2.5" Suspension Lift, JKS Disconnects, Currie Currect-Lync, RC X Flex Control Arms, Brown Dog MML, Daystar BL, RE Hand Throttle, Alloy Tube Seals.
USAJEEPOWNERS.com
lactrain is offline   Reply With Quote
Old 08-16-2008, 07:21 PM   #20
hotwiredxj
sorry, there was a posting problem with all my pics, please refresh and look now.
http://www.jeepforum.com/forum/showthread.php?t=593851
Old 08-16-2008, 09:50 PM   #21
lactrain
My bust, Im impatient ... glad to hear everyting went well how was your front to rear lignment ....
Any need to run out and get a rear adjustable track bar ... or a bracket?
Will you be having it aligned?
USAJEEPOWNERS.com
Old 08-17-2008, 08:32 AM   #22
signal34
i also have a 2"bl, but no engine lift. Would i still need the t-case drop? and could i use the spacers that come with the kit and add to the t-case drop i already have?
MY BUILD THREAD
US Army
signal34 is offline   Reply With Quote
Old 08-17-2008, 01:55 PM   #23
hotwiredxj
I will more then likley do the drive way alignment, if it is way off, I will let you all know. If you have an adjustable track bar cool, if not, I wouldn't sweat it. As far as the TC drop, if you already have one, you should be fine. you don't want to add to it, this one is about an inch in drop.
Old 08-17-2008, 09:50 PM   #24
jim_bert
Just picked this kit up, along with lactrain, let me know if you need to get an adjustable trackbar, bracket, or be OK without either. Thanks...
jim_bert is offline   Reply With Quote
Old 08-18-2008, 02:37 PM   #25
03_X
03_X's Avatar
how was the ride compared to the OME...
03_X is offline   Reply With Quote
Old 08-18-2008, 09:13 PM   #26
hotwiredxj
I was unable to meet up with the owner. I will try to get a hold of them this weekend. The alignment was dead on. I stopped by my local Firestone store, and it was fine. They adjusted my steering wheel as it a little to the right.
Old 08-19-2008, 09:31 AM   #27
03_X
03_X's Avatar
i have the OME kit, come to ohio, we can drive each others jeeps haha
Old 08-19-2008, 09:55 AM   #28
Unlimited04
Unlimited04's Avatar
I've found the OME for $600, but thats still pretty pricey compared to this lift. I dont eat cheeseburgers, my jeep does
and i understand how to subtract the factory bumper weight (10lbs?), I'm factoring that in
but realisticly, i'll buy a kit that is designed for what i'm doing, and I don't see this kit fitting the bill unless the vendor can show some support that the kit has a spring rate designed for heavy accessories. usually buying something because its cheap costs more in the end.
I would definitely like to know how the ride compares to OME, BDS and Rancho
Unlimited04 is offline   Reply With Quote
Old 08-19-2008, 02:22 PM   #29
Zennashton
Well there is no reason you cant add those things <as cash flow allows> after the lift install, And this kit does include a transfer case drop.
Zennashton is offline   Reply With Quote
Old 08-19-2008, 02:59 PM   #30
jeep2008
i agree but i was answering someone who asked whether he'll need anything else if he goes bb.also i must say that all of the people who sell the bb say that you'll need NOTHING more and that is a big lie .ok almost everyone...
my build thread
04TJ (SOLD)
01TJ (BUILDING)
Glock Forum
