Rims leak - JeepForum.com
post #1 of 7 Old 02-06-2014, 02:42 PM Thread Starter
Strelnikov
Rims leak
The aluminum rims on my '99 TJ Sahara leak so bad from corrosion that I have to air them up every other day. Not so big a deal in the summer but is a big deal when it's -10 F outside. A friend said he put flat fix in a wheel with a leaky aluminum rim and it stopped leaking. Anybody else tried this or have other ideas? I'd rather not buy new rims now.
'80 CJ-7 Iron Duke (project)
'99 TJ 4.0 Sahara (daily driver for now)
Strelnikov is offline
post #2 of 7 Old 02-06-2014, 02:49 PM
A4LiterV8eater
Oh wow, I haven't heard of an alloy rim leaking, but I have had steel rims leak. GM 3/4 ton rims were the repeat offender.
A4LiterV8eater is offline
post #3 of 7 Old 02-06-2014, 02:50 PM
Dave02TJ
Dismount the tires, use a grinder with 3m roloc discs and clean off the corrosion, then you could use bead sealer if you wanted.
Or take it to a shop and let them do it.
Dave02TJ is offline
post #4 of 7 Old 02-06-2014, 02:52 PM
Dave02TJ
It's almost a given that they will eventually leak out here in the salt belt. people that keep their tires full and wash their wheels tend to fair better.
Dave02TJ is offline
post #5 of 7 Old 02-07-2014, 02:13 PM Thread Starter
Strelnikov
Thanks for the ideas folks.
post #6 of 7 Old 02-24-2014, 08:20 PM
462FSJ
1973 J-Series Truck
Sometimes alloy rims come porous from the factory. Same it all the time at VW
462FSJ is offline
post #7 of 7 Old 03-03-2014, 09:50 AM
strvger01
1966 CJ5
and you could always just have tubes put in them. done that myself. just make sure you get tubes made for radial tires if that's what you're running.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
