Rims - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Tires & Wheels > Rims
Count Down to KOH Sale!Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-08-2014, 08:16 PM   #1
Denbowcj7
Rims
What size rim would it would best go with a tire width of 11.50
Denbowcj7 is offline   Reply With Quote Quick reply to this message
Unread 12-08-2014, 09:09 PM   #2
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
7-8".
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 12-08-2014, 09:17 PM   #3
Denbowcj7
Originally Posted by Wheelin98TJ
7-8".
whats stock?
Unread 12-08-2014, 09:37 PM   #4
Wheelin98TJ
JEEP FREAK
Both 7" and 8" are stock on a TJ.
Look here to help you identify what you have:
http://www.jeepforum.com/forum/f9/st...ations-452871/
Unread 12-09-2014, 05:16 PM   #5
Charley3
8 to 9
Charley3 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2014, 08:46 PM   #6
billiebob
Originally Posted by Charley3 View Post
8 to 9
Nope.... but best to check what the tire manufacturer recommends. Generally for off roading 4WDs stick with the narrow rim. If yer a street racer go wider.
My Uncles first Jeep was a Government Issued Jeep in 1944.
Back when ALL Jeeps were Government Issued.
billiebob is offline   Reply With Quote Quick reply to this message
Unread 12-11-2014, 06:23 PM   #7
rugsucka
8 to 9
Good luck finding a 9" rim.
If you plan on sticking to 10.5” tires 7" or 8" rims are both good choices. An 8" rim will encourage a flatter tread contact patch and more even wear.
If you plan on going to 12.5" tires in the future consider 8", but know that a 12.5" tire will also wear better on a 10" wide wheel for the same reason described above.
If you plan on wheeling and airing down your tires, it is advantageous to run the narrower wheel as it will hold a bead better. You will need to run a little less PSI to prevent crowning of the tire which will wear the middle of the tread faster than the shoulders.
FWIW, I run 12.5" tires on 10" wide wheels and air down to 10-12 PSI when on the trail and have never popped a bead despite putting plenty of sideload on the tires. Most 3 ply MT type tires are stiff enough to resist splitting the bead for even aggressive wheeling.
'00 XJ - Somewhat modified
'01 Venture - high mileage, paid for, shut it
rugsucka is offline   Reply With Quote Quick reply to this message
Unread 12-12-2014, 07:37 AM   #8
CJ7nvrstk
as stated, 7-8
RED Friday. Remember Everyone Deployed
CJ7nvrstk is offline   Reply With Quote Quick reply to this message
Unread 01-11-2015, 09:16 PM   #9
Charley3
9" wide are rare, but I've seen a couple. Though realistically there aren't many. Mamba wheels used to make a 16 x 9 (I own some) and I've seen another brand (forgot name). I don't recall ever seeing a 15 x 9
Unread 01-12-2015, 09:31 AM   #10
biffgnar
biffgnar's Avatar
For higher quality beadlocks in 17", 9" width is very common.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is online now   Reply With Quote Quick reply to this message
