Rim width v. Tire - JeepForum.com
post #1 of 17 Old 04-27-2014, 03:19 PM Thread Starter
VT-05WK
2005 WK
Rim width v. Tire
I'm looking at getting 17x9 wheels but the tires I'm looking at are recommended for wheel width 7.5-8.5. How important is it that I match these numbers?
'05 WK 4.7L V8, OME HD w/ Bilsteins, 1.5" Spidertraxx, Flowmaster 40 series
Cobra CB, Dipped Badges
VT-05WK is offline
post #2 of 17 Old 04-27-2014, 03:44 PM
biffgnar
biffgnar's Avatar
What size are the tires you want? Running a wheel narrower than manufacturer recommendation is common around here. Wider not so much.
Romney in 2020!
biffgnar is offline
post #3 of 17 Old 04-27-2014, 03:56 PM
krawler510
You're not into the V Dub stretch?
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #4 of 17 Old 04-27-2014, 06:00 PM Thread Starter
VT-05WK
2005 WK
I'm looking to either run 255/75R17 or 265/70R17. So could I mount either of those on the 17x9 wheel? Any issues I might run into?
VT-05WK is offline
post #5 of 17 Old 04-27-2014, 06:55 PM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
IMHO, a 9" wide wheel is too wide for those tires and will really put your sidewalls at risk for damage.
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #6 of 17 Old 04-27-2014, 07:23 PM Thread Starter
VT-05WK
2005 WK
Appreciate the help. I'm just looking for opinions cause I've heard different things. Any opinions are welcome
VT-05WK is offline
post #7 of 17 Old 04-27-2014, 07:42 PM
Luke95
Unless your running a 13.5-15 wide I would stay away from a 9 inch wide wheel. 7 or 8 will be fine!
5.2 ZJ Pushing a dana 30 as far as it will go.
Luke95 is offline
post #8 of 17 Old 04-27-2014, 07:44 PM
syphonation
agree. go with an 8" wheel.
syphonation is offline
post #9 of 17 Old 04-27-2014, 08:38 PM Thread Starter
VT-05WK
2005 WK
Im back and forth on 17x8 and 17x9. The only reason I'm look at the bigger size is cause I need to make sure I clear my calipers with aftermarket wheels
VT-05WK is offline
post #10 of 17 Old 04-28-2014, 06:03 AM
biffgnar
biffgnar's Avatar
If 17" diameter of wheels clears the caliper with either one, how does the wheel width affect that?
Romney in 2020!
biffgnar is offline
post #11 of 17 Old 04-28-2014, 06:56 AM Thread Starter
VT-05WK
2005 WK
On the wk, the 17 inch wheel clears but there are issues of rubbing the calipers with the back or the spokes. To correct this I need to look at offset and back spacing right?
VT-05WK is offline
post #12 of 17 Old 04-28-2014, 07:47 AM
strvger01
1966 CJ5
you are correct about the offset and back spacing.
but, those have nothing to do with the wheel width. you can have any width wheel customized to the correct offset and backspacing you need to clear your brakes. fortunately, most new wheels are made to accommodate the disc brake clearance issues on modern vehicles and you shouldn't have any problems getting any aftermarket 8" wide wheel to fit your wk.
1966 CJ5A, mods are coming
1966 Wagoneer, bone stock
strvger01 is offline
post #13 of 17 Old 04-28-2014, 07:58 AM Thread Starter
VT-05WK
2005 WK
Okay thanks for the clarification. I was just confused as to what I needed to look at and stuff like that. Thanks again
VT-05WK is offline
post #14 of 17 Old 04-28-2014, 10:40 AM
WXman
Look up the TREAD width of the tires you want and as long as it's equal to or slightly greater than the wheel width you will be fine.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #15 of 17 Old 04-28-2014, 11:47 AM Thread Starter
VT-05WK
2005 WK
Tread width is the same as section width correct? And what is considered to be slightly close? For example, the 255/75/R17 has a section width of 10 so would that be okay on a 9 inch wide wheel?
VT-05WK is offline
