Rim Size for 12.5 Wide Tire - JeepForum.com
post #1 of 4 Old 08-29-2009, 05:03 AM Thread Starter
reesemoe
What rim width should I run with a 12.5 inch wide Tire. The reason I am asking Is becuase im running a 8 inch wide rim on a 12.5 wide inch tire is that right or should I go up to 10 inch wide for my next rims.
My Build
www.jeepforum.com/forum/f22/building-roxy-860189/
reesemoe is offline
post #2 of 4 Old 08-29-2009, 05:52 AM
KKiowaTJ
It all depends on what you wheel and the look you want. If you want it to look wide and beefy a 15x10. If you wheel in the rocks more times than not, Get 15x8 with 3.75 or less BS. IMO i would run the 15x10's no matter what, Looks better with a wider stance and on road driving is a little better. The only down fall is if you want to air down to less than 10psi consistently. I say consistent as i have been at 8psi and never popped a bead, But not to say i wasn't lucky.
MOPAR!
KKiowaTJ is offline
post #3 of 4 Old 08-29-2009, 06:50 AM
1998zj
I am running 8" and like it. Seems to keep the tire on the rim pretty well. I run 9-10 psi off road and haven't lost a bead yet.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #4 of 4 Old 08-30-2009, 11:13 AM
+Crusader+
8's are perfect
"The only physical problem Obamacare won't be able to fix, is bustin' your @$$." Dennis Miller
+Crusader+ is offline
Would... (11.50 wide tire on 8" wide wheel) luv2getbig Tires & Wheels 2 07-17-2009 10:02 PM
What size rim for 14.5" wide tire? bigchevyman24 Tires & Wheels 2 05-24-2008 08:55 AM
12.50 wide tire on 4.75" BS rim Vacant Stare Tires & Wheels 1 01-10-2008 06:14 PM
how wide of rim do i use on a 14inch wide tire? TXjeepTJ Tires & Wheels 2 05-18-2006 05:17 AM
10.5 wide tire on 7" wide rim arcteryx23 Tires & Wheels 8 02-19-2006 05:06 PM
