Rim backspacing questions - JeepForum.com
post #1 of 5 Old 07-01-2010, 09:15 PM Thread Starter
joeksjeep
Dont kill me guys, i searched through the forum, and i didnt find the answers im looking for so heres the question
I am going to go with a 2in RE spacer bb for my 98 Tj
I wanna stuff 32's under it, well 31.8's haha
The problem Im having is they are all 11 in wide or wider, and interco is on back order for all their 32 by 9.5 an 10.5 tires so im SOL for those
If i were to get a 32x11.5 R15 tire, how much backspacing would i need??? I have 5.5 stock and with my BFG M/t 235/75r15 tires on the 5.5bs stock 5 spoke rims they rubbed at full lock so i put in some small washers on the stops and it stopped rubbing.
I had The aluminum rims with the 5.25 backspacing with some 235/75 r15 tires and it never rubbed at full lock.
So if i were to get, say, a 4.5 back spaced rim and put on the 11.5 wide tires, would that fit?
Being that the 235/75s are about 8 in wide i figured like 1/8 in back spacing for each .5 in greater width...
Ok is their a formula to figure this out??? And what would work best??? thanks for reading -joe
92 Xj 190,XXX miles needs love, and a TURBO HA!
150RwHp, 186 Lbs torque Rw, and all at 175XXX miles in my Xj
DD 98 wrangler sport 5spd 4.0 106,XXX miles
Chrysler Factory Trained Jeep technician, and A.S.E. Certified Master Tech
joeksjeep is offline
post #2 of 5 Old 07-02-2010, 03:50 PM Thread Starter
joeksjeep
any one?????
post #3 of 5 Old 07-02-2010, 04:10 PM
jdub36
I think 4.00-4.5 would be fine. If you want them to stick out more you could go down to 3.75 and it will push them out a little bit. Here is a pic of my 32's with 3.5 B/S.
jdub36 is offline
post #4 of 5 Old 07-02-2010, 04:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Any backspace dimension between 3.75" and 4.5" will work fine for an 11.5 (or even a 12.5") wide tire. If given a choice between 4.5" and 3.75" of backspacing, I'd choose the 4.5" every time to keep the wheels tucked in as much as possible. Go with nothing any wider than 8" where the wheel is concerned.
Jerry Bransford is online now
post #5 of 5 Old 07-03-2010, 08:10 PM Thread Starter
joeksjeep
thanks i much appreciate your responses guys !!!!
backspacing , wide , width , rim , wheel
backspacing questions?? jrgillespie1345 TJ Wrangler Technical Forum 1 01-07-2009 08:02 PM
2 Questions MML and wheel backspacing Saltine TJ Wrangler Technical Forum 15 10-19-2005 10:25 AM
backspacing questions TorxMonkey TJ Wrangler Technical Forum 19 10-18-2005 02:41 PM
Backspacing questions........again dieseljeep TJ Wrangler Technical Forum 1 11-01-2004 06:43 AM
More Backspacing questions Jeep14636 TJ Wrangler Technical Forum 3 06-29-2004 11:53 AM
