Rim advice - JeepForum.com
post #1 of 6 Old 04-07-2014, 08:37 AM Thread Starter
suzette
2009 JK Wrangler
Rim advice
Ok guys. So i got the lift on friday only to be extremely disappointed that it exaggerated my death wobble terribly. I can't pass 45mph. So the mechanic still has it
But anyway. The tires i have are 33x12.5x15 BFG.
I was told the rims i have on now which are (i guess) 6" wide will not give me the flared out look i want.
Sooo... Can you guys send me some ideas and pics of some rims?
Im thinking i need to go with 8" but you guys tell me....
Thanks
suzette is offline
post #2 of 6 Old 04-07-2014, 09:31 AM
tyvanwie
Yes, you need 8" wide wheels. Probably around 3.75-4" of backspacing as well.
tyvanwie is offline
post #3 of 6 Old 04-08-2014, 02:16 PM
DANSBIRD
Thanks
You can run stock rims, but you'll need spacers. This is exactly what I just took off of mine. Same tires, too. The rims are for sale, too, BTW :
Or, you can look aftermarket, as well. Ion makes an affordable 15x8, as does American Racing. Both offer the correct backspacing so you won't need spacers.
DANSBIRD is offline
post #4 of 6 Old 04-08-2014, 02:18 PM
DANSBIRD
You can also go 10" wide, but you'll hear bad things.. mainly "If you are trail riding and need to let out some pressure, you can't let out much w/ a 10" rim or you'll loose the bead". But, for the most part, you'd be fine w/ 10". Some people exaggerate the cons. They stick out about 4" away from the Jeep and they're deeeep.
DANSBIRD is offline
post #5 of 6 Old 04-08-2014, 02:20 PM
DANSBIRD
BTW... are you sure they're 6"? That seems awfully skinny. Are you sure they aren't already 8" wide? If so, and you want wider, go 10's.
DANSBIRD is offline
post #6 of 6 Old 04-14-2014, 05:42 AM
responder
Are factory steel rims not 7" and factory aluminum rims 8"? If you have the aluminum I am not sure what that would not work just like it did for DANSBIRD.
responder is offline
