Removing track bars - JeepForum.com
post #1 of 7 Old 09-23-2001, 10:01 AM Thread Starter
Brendan
Removing track bars
What does removing the track bars do? Does it decrease on road driving? Would you recomend it to a stock YJ driver? Should I throw away the track bars once i lift my rig?
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 7 Old 09-24-2001, 09:43 AM
Pantera
FYI, I tossed my rear track bar and have had no ill effects... Of course it doesn't handle like a Porsche (but it didn't before either)...
Eddie H.
91 YJ 4-Banger
Omaha, NE
Pantera is offline
post #3 of 7 Old 10-05-2001, 09:31 AM
damonejeep
What about removing the front track bar? Will this move create unsafe driving?
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #4 of 7 Old 10-05-2001, 11:44 AM
Nightclaw
No, as long as you don't push the Jeep too hard. I have been driving my Jeep without the sway bar or either track bar since I lifted it almost a year ago. Aside from body lean and a tendency for the alignment to "wander", there have been no ill side effects.
And the improvement you get in articulation from dropping the track and sway bars is quite notable.
Nightclaw is offline
post #5 of 7 Old 10-05-2001, 11:55 AM
GREGDOG95YJ
GREGDOG95YJ's Avatar
NIGHTCLAW IS RIGHT. AS LONG AS YOU DONT TRY TO DRIVE LIKE A BAT OUT OF HELL YOUR SHOULD BE FINE. I REMOVED BOTH OF MINE ABOUT A MONTH AGO AND IT DOES HELP IN THE FLEX DEPARTMENT. IT ACTUALLY HELP MY JEEP RIDE BETTER BY LETTING THE REAR SUSPENSION TRAVEL BETTER WHEN I HIT THE USUAL BUMPS ON THE DAILY DRIVE. I PUT QUICK DISCOS IN INSTEAD OF REMOVING IT ALTOGETHER MY WIFE DIDN'T LIKE THE BODY LEAN.
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #6 of 7 Old 10-08-2001, 03:15 PM
Rachi
what's a quick discos?
Rachi is offline
post #7 of 7 Old 10-08-2001, 09:15 PM
osburn
osburn's Avatar
Quick disconnects are for the swaybar. If you wheel, you need these.
As far as trac bars go, disconnect them off road for sure. If you don't, you will just destroy the mounts or the bolts if you wheel in twisty stuff.
On road, you'll never notice the rear one missing. Toss it.
On the front, you'll notice slower steering response with it off. I used to disconnect mine before a trail ride and reconnect it afterwards. I don't run with one in the front anymore at all.
Matt Osburn
Score 1032
osburn is offline
BB and adj track bars? rplowden Tires & Wheels 3 06-12-2008 08:39 AM
i need a walkthrough on removing the track bars on my yj intothexsjados Tires & Wheels 3 08-02-2007 09:07 PM
Track Bars Marcelo32109 Tires & Wheels 0 06-11-2006 10:51 AM
Adjustable track bars erickpl Tires & Wheels 14 06-10-2005 12:20 PM
Track Bars and Shackles Byerly76 Tires & Wheels 2 06-26-2001 12:19 AM
