Rear Shock Upper Mounts - Broken bolts
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#1 | |
I ended up cheaping out and went with the Rough Country 3" lift. I installed it this weekend, and most things went well.
I noticed the rear shocks were gone, and upon further inspection, noticed the upper bolts had snapped in the stamped perch. Anyone have experience with these? I was assuming I should douse it with pen oil, heat it up, and try drilling and using e-z outs. Any better plans? BTW, it's a 1998 XJ Sport. TIA, Theron
#2 |
Location: school - Campbellsville, KY; home - Oviedo, FL
That can be done, but on mine, we just drilled out the bolts, and re-threaded and put new screws in. The ez outs didn't work for us....
David White 95 XJ - Jacked up and abused White 98 XJ - Stock and babied |
#3 |
Use an air chisel & punch the weld nuts off. Then put new bolts in from the top. Takes about 5 min. per side. JIM.
96@6 & 92@3 |
#4 |
Thanks for all your help guys.
How accessible are the nuts from above? From what I could see, it looks like they're between stampings. You can't access it from the passenger compartment, can you? |
#5 | |
96@6 & 92@3 |
#6 |
I had the same thing happen to me and air chisled the capture nut & broken bolt out. The bolt is too hard for using ez-outs, plus the air chisel is quicker.
I used a washer & bolt and inserted back down thru the top of frame perch. You can access this area between the Frame & Tub liner. I used a larger socket to help keep the Tub Liner lifted up so not to gouge or cut my hands from the liner. Hope this helps.
97TJ / Shaved D60-14B / 106" WB / 42's / Detroits Front Leafs / Rear 4 Link Rock Mafia Offroad & Hitman Offroad |
#7 |
Nice Doggy
I had the same issue. I used an air chisel to knock out the welded nuts. Next coat a nut with never sieze and use masking tape to hold the nut in place in a wrench. Poke a whole through to the threads and pre run the bolts through.
Feed the wrench through the access hole and screw in your bolts, then remove the wrench. It truly is a ten minute process. Good luck, it was learned here on this website. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
