RE 7.5" lift questions - JeepForum.com
post #1 of 6 Old 08-26-2005, 10:11 PM Thread Starter
joshmacc
I just bought the RE 5.5" long arm kit and upgraded to the 7.5" springs and got the back up to 7.5" also on my 2000 XJ. I'm going to be running 35's and had some questions. Is there anything extra that I will need thats not in the kit other then the SYE and Driveshaft. Some people recomend the shims for the back. Anything else along those lines? also will my I6 handle a 35" MT/R good enough stock? Or will I have to change gears? I mostly stick to roads driving atleast 30 miles a day. And only get to hit the trails about once a week. So any opinions? Thanks
Also do you think 7.5" is good enough for the 35 MT/R's?
joshmacc is offline
post #2 of 6 Old 08-26-2005, 10:25 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
First...to anybody else reading this...don't skip the part where he says he has an XJ...
(didn't want anybody else to freak out by reading just your last sentence)...
I'm not real sure on the lift question...but the answer to your gear question will depend on which transmission and which gears you're currently running...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 6 Old 08-27-2005, 10:26 AM
under_psi
i dont own an XJ, but a good friend of mine does, and he has 6.5" of RE lift and he has 35" maxxis creepy crawlers....he also has 4.56 gears.....and i do as well with my 35's.....i would not want any higher gears....it just makes negotiating obstacles easier........and stresses the drive train less with the (lower) gears.....
what is your stock gearing.....
What's coming through is alive. What's holding up is a mirror. But what's singing songs is a snake looking to turn this piss to wine. They're both totally void of hate, but killing me just the same. The snake behind me hisses what my damage could have been. My blood before me begs meopen up my heart again. And I feel this coming over like a storm again. considerately. Venomous voice, tempts me, drains me, bleeds me, leaves me cracked and empty. Drags me down like some sweet gravity.
under_psi is offline
post #4 of 6 Old 08-27-2005, 09:49 PM Thread Starter
joshmacc
3.55 I believe
joshmacc is offline
post #5 of 6 Old 08-28-2005, 01:04 PM
creature
creature's Avatar
what kind of rearend do you have or plan on putting in? And you may want to consider rear disc brakes if you enjoy stopping within a reasonable distance
-Shawn
creature is offline
post #6 of 6 Old 08-28-2005, 04:56 PM
got4-Lo
with that much lift, might have problems with axle wrap since XJ's are SOA in the rear. dependding on how bad it is u moight want to conisder a ladder bar
stretched *** tj
got4-Lo is offline
Re la 5.5" lift questions sixpointoh03 Tires & Wheels 1 01-14-2008 03:21 PM
Questions on 2" BDS lift Bishop Creek Tires & Wheels 11 08-01-2007 06:23 PM
Installing a RE 3.5" lift on an XJ and had a few questions.. webqaz Tires & Wheels 4 12-23-2006 05:30 PM
OME 2.5" HD spring lift questions martinsburgjeep Tires & Wheels 11 05-26-2006 05:16 PM
3" TJ lift questions limecolbyjack Tires & Wheels 2 12-23-2005 09:53 AM
