RE 3.5" Standard or SF - JeepForum.com
post #1 of 6 Old 04-27-2004, 03:21 PM Thread Starter
supertj4415
supertj4415's Avatar
Well, I've got my mind set on RE. Everyone only has good things to say about their lifts, plus the price seems right.
One question though...
Im mostly gonna be playin in the mud, because thats what most available around here. However, I do make a few trips south to Mark Twain Forest and St Joe Park, where more flex is required.
Does the standard with 33's offer enough flex or should I go with the superflex?
Thanks for everyone's help.
Tim
PS: Jason I'd really like to hear from you on this one.
2000 TJ Sport
3.5" RE SF-- LoD--35" BFGs--Pioneer System
FUTURE MODS:
44 front/9" rear w/ 4.88s and ARB
JEEPS won a war....your Honda mowed my lawn
supertj4415 is offline
post #2 of 6 Old 04-27-2004, 11:19 PM
Bighaeb
Bighaeb's Avatar
Im very familiar with the wheeling in your surrounding area (Potosi, MTNF Service Roads, Ft. Leonardwoood, St. Joe) and from what I've experienced, I'd say you could get away with the standard kit no problem. And with the 33s, it will be rare that you find an obstacle that will stop you.
But also think of the possibility that you might want to go to other spots one day, I.E, Superlift Offroad park, Badlands, and maybe even Moab one day, so the extra flex that comes out of the Superflex kit would be pretty helpful in these types of situations.
"Rigged for her pleasure"
Jeepless for now
Bighaeb is offline
post #3 of 6 Old 04-29-2004, 08:19 PM
zzquik
zzquik's Avatar
well, if you have a little bit more money to spend and want a little more offroad capabililty just get the SF. I have the standard lift and it does just fine with the wheelin i do which is mainly mudding..one of the only major differences in the two systems is probably just the control arms, the trac-bar, extended brake lines, and the sway-bar components..overall, the standard lift is the same as the SF system but its just a little bit cheeper and lacks a couple of components that the SF has..id say the SF if u had the extra money but if you dont want to, just get the standard lift like i have where you can eventually add the other components, maybe even get the long-arm components later on for the ultimate rig..my .02$
Blue Jeep Club Member #68
02' X
RE 3.5" SL
RE Trac-Bar
DT-3000's
33" BFG AT's
AR Pythons
K&N
Jeeperman Front Bumper
$3.73's$
zzquik is offline
post #4 of 6 Old 04-30-2004, 11:50 AM
YJinSD
YJinSD's Avatar
installed the standrd 4in on my buddys ride. Clears 32s nice but not sure if you would rub with 33s.
http://f2.pg.photos.yahoo.com/ph/keo...&.dnm=517c.jpg
YJinSD is offline
post #5 of 6 Old 05-02-2004, 10:33 PM
YJinSD
YJinSD's Avatar
RE isn't the last word i have a 3 1/2 in black diamond that installed much easier than th RE and performs as well if not better, and would clear the 32s the same
http://f2.pg.photos.yahoo.com/ph/keo...90.jpg&.src=ph
YJinSD is offline
post #6 of 6 Old 05-03-2004, 12:58 AM
RockPaws
RockPaws's Avatar
The 3.5" SF kit works fine, of course not a well as the long arm. Their are a few items I highly recomend.
1) If your just getting the straight SF kit, upgrade the upper arms on both axles to adjustable. You will then be able to adjust the pinion and caster angles much better.
2) Adjustable front and rear track bars.
3) SYE kit w/ HD Tom Woods shaft.
My current set up has all adjustable control arms, 33" tires and a SYE. The adjustablity has been great. Very glad I did all the upgrades.
One customer installed the SF kit and has vibs due to no adjustabilty. I think their going to do the upgrades now.
Check with Jason at Red Rock 4x4.com he really knows his lift kits. They do a lot of product testing, what works and what doesn't.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
RE 3.5" standard snubs05 Tires & Wheels 4 12-31-2005 05:18 PM
RE 4" standard YJ kit StuckInMud94 Tires & Wheels 2 03-19-2005 01:25 PM
RE 3.5" Standard Optik45 Tires & Wheels 8 11-11-2004 12:59 AM
2.5" RE standard Durbahn Tires & Wheels 4 08-28-2003 11:33 PM
2.5" RE Standard Duty. Crusoe Tires & Wheels 2 06-25-2003 10:24 AM
