Rausch Creek tires - JeepForum.com
post #1 of 30 Old 02-18-2014, 10:31 PM Thread Starter
thaduke2003
Rausch Creek tires
Okay. I'm in upstate NY, and my preferred playground is Rausch Creek. I've seen any number of different tires there, and I've run both Firestone Destination A/T's and KM2's there with great success and zero issues with each. Obviously the KM2's got further with fewer worries.
Anyway, I'd love to hear from other Rausch-goers with firsthand experience only- what has worked for you, what hasn't?
The end of all this will help me decide what to put under the YJ I'm building. Price will be a big factor, so nothing ridiculously spendy will get much thought, but I'm open to suggestions- cheers- Mark W.
thaduke2003 is offline
post #2 of 30 Old 02-20-2014, 08:55 AM Thread Starter
thaduke2003
Wow- what an overwhelming response... Thanks! Mark W.
post #3 of 30 Old 02-20-2014, 10:05 AM
biffgnar
biffgnar's Avatar
What has worked for me at Rausch? MTRs. But my jeep is a DD so I have to run a tire that is a good multi-use. If a dedicated trail rig, might run something different.
biffgnar is offline
post #4 of 30 Old 02-20-2014, 12:28 PM
Ed209
Do the KM2s clear mud good for you up there? There are some on this forum who say the KM2 gum up and turn into slicks in mud.
Ed209 is offline
post #5 of 30 Old 02-20-2014, 06:47 PM
ssyj94
I ran km2's for awhile at RC ended up with a giant hole in the sidewall when aired down below 10psi. Before the hole at 12psi they hooked well up trail 5 hillclimb and other blacks. Cleaned well in local slop and were a good all around DD tire for picking them up used then putting 25k on them and wheeling.
I now run creepy crawlers and can say they hook up 100x better with no sidewall worries. If your planning on putting a lot of miles on I'd look toward radial treps or mtrs. If its a second vehicle and occasional driver creepy's are an awesome option(shop around you'd be surprised how much can be knocked off a set).
My build:
ssyj94 is offline
post #6 of 30 Old 02-20-2014, 07:55 PM
krawler510
If this is a trail rig then run what the big boys run, sticky Maxxis, Krawlers, Nittos.
But for normal people, my wheeling group has run:
Trail Grapplers
Duratracs
Toyo MT
MT/R
Hankook MT
No failures on any.
Duratracs were the weakest in mud.
I'd run any of them. I am beyond impressed with my Hankooks. I had low expectations but they claw up everything just as good and better than some of the others.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #7 of 30 Old 02-20-2014, 09:30 PM Thread Starter
thaduke2003
The rig will be a DD 90% of the time, but I don't mind driving daily on M/T's.
As far as the KM2's in mud, they weren't great, for sure. They weren't as brilliant as I'd hoped on slickrock, either. That's why I'm considering other options. That, and price. I also had a small stick puncture a sidewall on an EASY local trail one time, and if I hadn't had a full-size, matching spare, I would have been stuck. It could have just been crappy luck, but it certainly made we think- Mark W.
post #8 of 30 Old 02-20-2014, 09:30 PM Thread Starter
thaduke2003
Also, I'm more into rocks than mud, so I'd be willing to trade mud prowess for grip on rocks and durability- Mark W.
post #9 of 30 Old 02-20-2014, 10:46 PM
achilless
Just wondering where you're located. I am in Utica, NY. Rouche trip??!!
2002 TJ Sahara: 4" Zone/ 1.25" BDS body lift. 35" Km2's, Dana 44-LSD, Dana 30-Lokka Locker, JKS 1" motor mount lift, TheDirtWorx bumper/carrier, Smittybilt XRC 8000 Winch, D rings front + rear, Hi-lift
achilless is offline
post #10 of 30 Old 02-20-2014, 10:57 PM Thread Starter
thaduke2003
I'm over in northern Dutchess County. My rig is still a long ways from being Rausch-ready, sadly, but in a few months, hopefully, it will be- Mark W.
post #11 of 30 Old 02-21-2014, 05:25 AM
TimV
Goodyear MTR's are the best I have run there. I've used KM2's, blue label krawlers, and now the MTR's. These hook about the same as the krawlers, but much nicer ride on road. I don't feel like I gave anything up switching to them, other than a lot of rotating mass.
It's not an addiction. It's a way of life.
TimV is offline
post #12 of 30 Old 02-22-2014, 08:50 AM
Fourtrax
I run 37" Toyo Open Country MT's at Rausch. I do mostly reds and blacks and air down to around 12 lbs. I have yet to get stuck or find an obstacle I could not tackle. I have run everything from BFG ATKO's to KM2's to bias ply swampers and these are the most impressive tire yet. They are very quiet on the road and awesome on the rocks. I highly recommend these tires.
Fourtrax is offline
post #13 of 30 Old 02-22-2014, 09:32 AM Thread Starter
thaduke2003
I've heard a lot of good things about the Toyos- my big issue with them is availability- there is not a local store that regularly stocks them, meaning that if I somehow pop two, the rig is out for a week or two, whereas with most of the others, I can at least get them via Tirerack.
As for the MTR's, are people referring to plain MTR's, or the Kevlar-reinforced model? Mark W.
post #14 of 30 Old 02-22-2014, 09:38 AM
krawler510
Probably the Kevlar since that's all they make now. Right?
I wouldn't beat yourself up too much on tire decision. Most off road tires will do pretty great.
post #15 of 30 Old 02-22-2014, 09:52 AM Thread Starter
thaduke2003
I know- I'm just looking for input. By price, I'm really considering the Dunlop Mud Rovers- they're about $25-35 less per tire, but I haven't heard anything about them at Rausch. For quality, I keep hearing a lot of good things about the Toyos, but I can't find them locally, and the MTR/K's, but they're pretty spendy ($206 per tire in 33/12.5/15 on Tirerack), so that's tricky. We'll see how things go, but it's looking like budget might win out at this point, as I'm pretty income-limited- Mark W.
